Hi everyone,
this fork brings Bosch, Siemens and Neff dishwashers, washing machines, ovens, hobs, hoods and fridges into Home Assistant over your local network. Once it’s set up, everything stays local.
Sign in right inside Home Assistant
During setup you just log in with your Home Connect account and the integration fetches the appliance profile itself. No extra tool, no juggling files, and it works from any device.
What else is in there
Over time a lot of my own tweaks went in, plus plenty of fixes from your issues. Names and options match the Home Connect app, in English and German.
Tested at home (all Siemens)
• Dishwasher SX63HX52BE
• Hob EX851LYV5E
• Oven HB774G1B1
• Hood LC91KLT60
I test every patch on these four first, in detail. Everything they can do is covered by now. For other appliances and models with more features I need your help: with your diagnostics and debug log I can add them properly.
Install
- Open the repository in HACS, it always takes you to the latest release:
Manual: HACS > â‹® > Custom repositories > https://github.com/Asmir1975/homeconnect_local_hass-UI (Integration)
Download it and restart Home Assistant
Add the integration and pick Sign in with Home Connect:
- The sign-in with screenshots: Guide
Already have your profiles? You can also upload the ZIP files from the profile downloader.
If something’s off
I’d prefer an issue on GitHub. What helps most is a short description of what you did and what happened, plus the debug log and the diagnostics file. How to get both, with screenshots: Debug log and diagnostics
No GitHub account? A PM or an e-mail works too, the address is in my GitHub profile.
Join in
Testers with any kind of appliance are welcome. And if you’d like to help with the code, PRs are welcome too.
Project: GitHub
