Home Connect not working?
I have been using Home Connect for a year or so.
I think it stopped working as i installed 2022.10.0. No updates or errors in logs.
So i thought i will re-add the integration. But i get strange error message i have not seen before?
It’s from the my: oauth2 thing, i think? My adress got rejected?
But in Home Connect dev portal i am not using the my adress as suggested in integration page, instead i am using my local as suggested under the manual config part.
I have tried my.-adress but get:
“client or redirection URI not authorized”
And when i use my local uri i at least get past that error and can authorize in home connect, but i get the rejected message as home assistant-my wants something accepted? Nothing about this in the docs?
What am i doing wrong, don’t understand this last part where the rejection error shows?
I can’t show any logs or anything since nothing shows in there, everything stops as the redirects are poping up.
I have also tried deleting application in Home Connect dev, and creating a new, but no joy.
Thanks for any help
Not sure if mine works or not.
The door state is unavailable and that is usually when the integration has failed.
But other sensors seems to work, nothing is running at the moment but they are at least not unavailable.
I’ll have a look when I get home from work.
The duck is splashing around in the washing machine so the integration seems to work for me
In home connect dev portal, are you using the my.homeassistant… adress as uri or your duckdns as suggested in the integration instructions?
thanks for your help
Updated Home Assistant and now it works?
So must have been something in the 10.0 version that was wrong?
I’m using 10.0 and it works here.
I jumped to early, still won’t get the entities to updated when the dishwasher runs.
Was able to authenticate on the my… adress uri, but nothing updates as the integration is added.
And nothing in logs.
Have no idea what to do? Anyone have had the same issue, and got it to work again?
