Home Connect timer hh:mm:ss instead of hh:mm
I integrated my oven with the Home Connect Integration.
I’d like to set the alarm clock timer to 45 seconds.
The integration just allows to set the timer in hh:mm. I can’t change the entity to allow hh:mm:ss:
Is there a way to change the behaviour? I’d also like to see the actual remaining time in hh:mm:ss, too.
The attribute of the timer shows 00:00:00:
[time.backofen_wecker]
Backofen Wecker 00:00:00
Which card are you using to set the timer value?
It is a tile card:
to set the timer, i.e. the other one
Sorry for the delayed reply.
It is the same card, just clicking on it. This leads to the detailed view of the entity.
It is called time.backofen_wecker:
