Home Connect
No I did not experience this, but have you examined alle the device entities whether any other entity holds the right power status?
@ghassan I ended up creating the following GitHub issue to check and found out that the washing machine unfortunately doesn’t send any power off events.
@jarrah,
I have a Siemens dishwasher which doesn’t have this problem.
Strange that your Bosh washing machine disconnects on power off. My dishwasher stays connected and still can be powered on/off.
Yes - in the Home Connect app you can enable Remote Start permanently under machine settings.
I dont find this feature. not in the laiundry and dryer settings. would be cool to have it.
Could you please tell me where? Cause I can’t see it. Thank you in advance
I can only comment on the dishwasher unfortunately
In the Home Connect app, select your dishwasher, then go to Settings. First two options are Remote Start and then Remote Control Level where you need to select Permanent Remote Start.
It seems I don’t have that option on mine :frowning: donno why
Guys, i need to start on the Dishwasher ECO mode + Speed on Demand but i don’t have any sensor for Speed on Demand. Which sensor is that and how can i program this to get it in HA?
I have Siemens.
Someone any suggestion about the possibility?
If you don’t have a switch that represents it, them I guess you wont be able to control it.
Ok, only the the Eco mode without that option takes 3,50 hour. Is that really eco? Are you not using that option?
Hi @Himdola ,
Yes it takes longer time but it uses less electricity and water.
You can find the Water/Electricity usage for each program in the app. in the top right corner
the usage indication changes when you select another program
Perhaps you can use the Home connect API directly?
There is also a Node red nodes you can use to control Home connect appliances.
Can’t seem to find an answer anywhere, but is there a way to get a power consumption entity for the devices connected through Home Connect?
Would be cool indeed. The Home Connect App itself mentions connecting with Energy Managers. Would be great if HA could act as one.
How do we go about getting that info? I don’t see it in the API docs, so maybe that info isn’t available?
I’m not a coder, never worked directly with APIs so I wouldn’t know what a next step could be.
As far as I know it’s not exposed.
I have used every endpoint in the API on my washing machine.
Sadly the good stuff is missing.
Like how much left in the idos compartments, how many kg of clothes is it washing, energy and water.
I just got an email from Home Connect asking me to change to SingleKey - will this break Home Assisntant integration or is it safe?
Home Connect now works with SingleKey ID. This means you need to make a change to your login. But, don’t worry, it’s quick and easy.
SingleKey ID uses Single Sign-On authentication to enable the use of one login for many accounts . It is the most convenient way to quickly and safely access your Home Connect profile as well as many partner websites, apps and e-shops.
