Home Location Incorrect
One of my automations that is based off of the sunset and sunrise has been off - turning on and off no where near the these timeframes.
Looking into it, it is based on an incorrect location of my house. Somewhere in the Netherlands. I’m not able to change the location in the UI since HA is indicated that the location was set in the configuration.yaml file. Even that was set to the long and lat of my house, but it still says the house is in the Netherlands. I have now removed all references to a long and lat, but it still indicates the same location and I’m not able to change the house in the UI.
For each change I restarted the docker container running HA.
Any ideas on how to correct this?
I solved the issue
You can set your geo location in the config.yaml, I’ve done mine for earthquake monitoring
geo_location:
  • platform: usgs_earthquakes_feed
    feed_type: “past_month_m25_earthquakes”
    radius: 325
    minimum_magnitude: 2.5
    latitude: ##.##########
    longitude: ##.##########
That’s a pretty cool idea (earthquake monitoring).
