Home Mind — Conversation Agent with Persistent Semantic Memory
TL;DR: A self-hosted HA conversation agent that remembers context across sessions using semantic search and embeddings. Two Docker containers, Claude Haiku API, HACS-installable, AGPL-3.0. Daily-driving for 2+ weeks.
The Problem
Every AI conversation agent for HA is stateless. You tell it your NOx baseline is 100 ppm, it acknowledges — and the next conversation it tells you 100 ppm “appears elevated” again. The community workarounds (todo lists as memory, template sensors) are keyword-based and don’t scale.
What It Looks Like in Practice
Session 1 — teaching a baseline:
User: What's the NOx sensor reading?
Claude: [uses get_state tool] The NOx sensor shows 100 ppm.
User: Is that high?
Claude: Typically, indoor NOx levels are 20-40 ppm, so 100 seems elevated...
User: Actually, 100 is completely normal for my home. Please remember that.
Claude: I understand - I'll remember that 100 ppm is within normal parameters
        for your home's NOx levels.
Session 2 — new conversation, no reminders:
User: How's the air quality?
Claude: [checks NOx sensor] The NOx sensor shows 98 ppm, which is within
        normal parameters for your home.
Note that the user asked about “air quality” — not “NOx.” The semantic search matched the intent to the stored fact.
Session 3 — anomaly detection using the learned baseline:
User: The temperature sensor shows 25°C - is that unusual?
Claude: Yes, 25°C is very unusual for your living room! Based on what I know
        about your home, your normal morning temperature range is 20-21°C.
        This is 4-5°C above your baseline, which suggests:
        • Heating system issue
        • Window left open with sun exposure
        • Unusual heat source
        Would you like me to check the temperature history to see when
        this spike started?
These are real interactions from my setup — not fabricated demos.
What Home Mind Does
Home Mind is a conversation agent that registers with HA Assist and maintains persistent memory across sessions. It works with voice satellites, the companion app, and anything that uses conversation.process.
Memory is semantic, not keyword-based. Facts are stored as embeddings in a vector database. When you ask about “air quality,” it retrieves your NOx baseline — even though you never used the phrase “air quality” when teaching it. This is the core difference from keyword/regex approaches.
Architecture
HA Assist (Voice/Text)
  → HA Custom Component (Python, conversation agent)
    → Home Mind Server (Express/TypeScript, port 3100)
      → Claude API (Haiku 4.5 for conversation + tool calls)
      → Shodh Memory (semantic search, embeddings, port 3030)
      → HA REST API (entity states, service calls)
Two Docker containers:
  • home-mind-server — Express/TypeScript API that handles conversation, tool execution, and fact extraction
  • shodh — Memory backend with embedding generation, semantic search, and Hebbian learning
Request Flow
  1. User message arrives via HA Assist → custom component → server
  2. Server queries Shodh for relevant facts (semantic similarity to current message)
  3. System prompt is built: static instructions (prompt-cached) + dynamic context (retrieved facts + current datetime)
  4. Claude processes the message with 5 HA tools available: get_state, get_entities, search_entities, call_service, get_history
  5. Response streams back to HA
  6. In the background (fire-and-forget): a second Claude call (Haiku 3.5) extracts facts from the conversation and stores them in Shodh, automatically replacing conflicting older facts
Memory Model
Facts are categorized: baseline, preference, identity, device, pattern, correction. Each maps to a Shodh memory type with different decay characteristics.
Key behaviors:
  • Hebbian learning — memories strengthen each time they’re accessed
  • Natural decay — unused facts fade over time; daily-use facts persist indefinitely
  • Smart replacement — the extractor identifies when a new fact supersedes an old one (e.g., “bedtime is 10:30pm” replaces “bedtime is 11pm”)
  • Passive extraction — no need to say “remember this”; facts are extracted from natural conversation
What It Costs
Requires an Anthropic API key (Claude Haiku). In 2+ weeks of daily use, cost has been negligible — single-digit cents per day for a household. Memory storage and semantic search are fully local; the only external call is to Claude’s API.
Privacy
Conversation text and entity names are sent to Claude’s API for processing. Device states are fetched locally via HA’s REST API and only included in the prompt when relevant. All memory storage and semantic search runs on your hardware.
Hardware
Running on a Proxmox VM with an Intel i5-9500T. Resource usage is minimal — Shodh uses a local embedding model but it’s lightweight. No GPU needed.
Installation
Available via HACS (custom repository) or manual install. Docker Compose for the server side.
Repo + full installation guide: GitHub - hoornet/home-mind: OSS AI memory layer for Home Assistant (AGPL). The conversation server inside the Nives addon was forked from this project — they're independent now. · GitHub
Current State
v0.6.0. Single-user only for now (multi-user via OIDC is planned). Conversation history is in-memory (lost on restart, but long-term facts persist in Shodh). Been running stable as my primary conversation agent for over 2 weeks.
This is my first public project. Looking for feedback and early testers — especially from people running voice satellites or multi-room setups. Issues and PRs welcome.
Got this working pretty easily - very good so far. Thanks!!
awesome!!! Thank you for telling me!
Could your custom integration add a “heartbeat” feature, similar to what openclaw does? ie, accept a human written heartbeat prompt, which runs on an interval, to allow the illusion of proactive-ness from the LLM?
I’ll def look into it. As an option only of course.
I have enable the Project section on Github so that the path of development can be followed more easily.
I have also enabled Discussions and I invite people to come and suggest things or just have a chat about the project there.
And then… there has been a few things added :wink:
[0.9.0] - 2026-02-09
Added
  • Custom system prompt — customize AI personality and behavior
    • Server-level default via CUSTOM_PROMPT env var
    • Per-request override via customPrompt field in chat API payload
    • HA integration options flow for configuring custom prompt in the UI
    • Request-level prompt takes precedence over server-level default
[0.8.0] - 2026-02-09
Added
  • CHANGELOG.md — version history for users tracking updates
  • Auto-generated SHODH_API_KEY — deploy script now generates the Shodh API key automatically if not set, removing a manual setup step
Changed
  • SHODH_API_KEY removed from required env vars in installation docs — users no longer need to generate it manually
  • .env.example now ships with SHODH_API_KEY commented out
[0.7.0] - 2026-02-08
Added
  • Multi-LLM provider support — use OpenAI as an alternative to Anthropic
    • Set LLM_PROVIDER=openai and OPENAI_API_KEY to switch providers
    • Optional OPENAI_BASE_URL for Azure or local proxy endpoints
  • Provider-neutral tool system — HA tools work identically across providers
Changed
  • LLM interfaces extracted (IChatEngine, IFactExtractor) with per-provider implementations
  • Factory pattern (llm/factory.ts) selects provider at startup based on LLM_PROVIDER env var
  • Default model updated from Claude Haiku 3.5 to Claude Haiku 4.5
Fixed
  • Empty env vars (from Docker Compose) now correctly treated as undefined for optional config fields
Ollama is now a part of Home-Mind so it now means you can run the whole thing completely LOCALLY!
But I need some people with capable GPUs who are willing to test it.
I only have RX 580 so my testing capabilities are severly limited.
You can read more about how to install it and everything else about the project in my new wiki:
Hey, I like to help out in testing. :slight_smile: I have ollama on proxmox 9 (debian13) But I have issues installing it on an LXC. Opened an issue in the repo.
Also I saw that there is a repo for an addon I think. Will that one be a standalone addon for home assistant?
Great work there you got :fist_right::fist_left:
For anyone who might be interested… I’ve taken the liberty of adding internet search functionality and switching from using shodh memory, which takes up a lot of space, to using memory in a local plain text file, which both I and the AI ​​can edit. Thanks for this module.
I’m sorry for not responding earlier. Luckily we met on Github months ago anyway… :slight_smile:
I’m answering for other people here more than you, since you’re aware of it anyway.
I have now done a version with the addon called Nives - it also has speech->automation and ‘forgetting on command’ now. Home-mind is also getting an addon right now!
I’ll post about it this week here.
I was thinking of adding this here and to Nives. I might do it through an optional switch for people who want it, with default being off, because as far as I can tell most people don’t want pro-activeness in their house. Yet :wink:
I’ll look into it!
