Home Panel - A web frontend for controlling the home
latest safari and chrome on macOS mojave 10.14.6
Hi, just updated yesterday and now i canā€™t dim my light or change the color if i long press button nothing happen.
Please increase the size of the card (3+ height) to show the color picker.
There is an RFC open in GitHub for this or something similar to improve on this and for smaller cards.
https://github.com/timmo001/home-panel/issues/418
Hello, thanks for this great piece of work.
I just installed the add on, and Iā€™m having the same issue.
BUT, when I set the port to 8123, the son addon just wonā€™t start. No log or anything. Reverts to normal when changing it back to disabled.
I suppose itā€™s a bug, so Iā€™m raising an issue in github.
Cheers!
My apologies, that port is of course the same as Home Assistant. I meant to say 8234 or something similar. :slight_smile:
Home Panel v2.1.0 :tada:
GitLab CI
https://github.com/timmo001/home-panel/releases/tag/v2.1.0
This release adds support for charts :chart_with_upwards_trend: as well as a few layout tweaks and fixes. Plus a bunch of updates :arrow_up: and vscode tasks and devcontainer support. :rocket:
Changes
  • 5b349f1 :arrow_up: Update dependency @feathersjs/configuration to v4.3.2 (#489)
  • 70fc017 :hammer: Cleanup logs
  • 9cea390 :hammer: Add support for markdown height and standardise height
  • eef6297 :ambulance: Fix iFrame height
  • 86ac06e :hammer: Reset card props when changing type
  • ab3fd19 :arrow_up: Update feathersjs to 4.3.2
  • 5dc5649 :arrow_up: Upgrade curl
  • cee0ff5 :arrow_up: Update dependency snyk to v1.228.2
  • e6e8aaa :arrow_up: Update dependency @types/jsonwebtoken to v8.3.4
  • a26a0cc :arrow_up: Update dependency ts-node-dev to v1.0.0-pre.43
  • 05c798a :arrow_up: Update dependency react-scripts to v3.1.2
  • 223e336 :hammer: Make camera entity use Image component
  • 08dd5d8 :arrow_up: Update dependency flow-bin to v0.108.0 (#505)
  • 3803098 :arrow_up: Update dependency socket.io-client to v2.3.0
  • 2398545 :arrow_up: Update dependency helmet to v3.21.1
  • a247b72 :arrow_up: Update dependency react-select to v3.0.5
  • 15e5327 :sparkles: Charts (#510)
  • 3905525 :arrow_up: Update feathersjs
  • 71f2e9b :fire: Rework entity selection and move items
  • f44adaa :sparkles: Setup tasks and devcontainer
  • bfa7cea :hammer: Add start all task
  • 26c5b6b :hammer: Add docker to devcontainer
  • c68cc8b :hammer: Add markdownlint to devcontainer
  • b7be74e :hammer: Pass ssh keys to dev container
  • 75b0392 :hammer: Fix zsh path
  • e583d83 :hammer: Cleanup
  • 1131325 :fire: Fix chart updating
  • e1bbb5b :hammer: tweak chart position
  • edaa242 :hammer: Update chart on prop change
  • a415cd3 :hammer: Leave chart props the same when switching between
  • 548e056 :arrow_up: Update dependency snyk to v1.228.3 (#517)
Full Changelog
Great! Thanks ā€¦ waiting update for hassio now ā€¦ :sunglasses::+1::face_with_monocle:
Awesome, thanks!
How do I persist my configuration outside of the container? Ouroboros automatically upgraded me to 2.1.0 (:smiley:), but I seem to have lost everything I had set up (:fearful:).
Of you used version 1.x and upgraded to 2.x then your data will be lost. according to the thread hereā€¦ but if u upgraded fom latest version to the very latest version normally persistent data shuld have been saved. Do you use hassio @michaeldavie ? I am still waiting for the updte :confused:
No, I just use Docker for both Home Assistant and Home Panel. Looking above it seems that I might just need to map the /data folder as a volume for the container; Iā€™ll give that a try.
Yes ā€¦ then u will have to map /data to a local path like: -v /home/hass/Home-Panel/data:/data
Is there a way to include a map showing tracked devices?
:sweat_smile: I realized that last night (that 8123 is HA), and itĀ“s working properly now.
BTW, waiting for the Addon version!
Can anyone help me? Iā€™m struggling for a while trying to get it run properly Iā€™m not sure itā€™s a bug or me doing it wrongā€¦.I get a bunch of LOG codes that I donā€™t understand every time I log in the home panel there are more and the same codes.
The major problem is that Iā€™m not able to make custom themes fist time there is one but second time there are ā€œno themes foundā€ and pressing pencil of the configured themes give me a blank screenā€¦
I canā€™t find any file that store the theme or other home-panel data.ā€¦ is there one or did I install it wrong?
What should I do? Overall it works but non themes.
Home Panel v2.2.0 :tada:
GitLab CI
This release adds support for input_select entities as well as a few tweaks and fixes. There is also a new color wheel for light entities.
You can now also expand cards to show all features by long pressing the card.
Changes
  • 3537d96 :books: Add missing volume docs
  • 35860b1 :arrow_up: Update mui monorepo to v4.4.3 (#518)
  • 8901f1f :arrow_up: Update dependency snyk to v1.228.5 (#521)
  • cb3870c :books: FAQ wording
  • 40a2e11 :books: Remove legacy docs
  • 4f0310f :arrow_up: Update dependency @types/node to v12.7.7 (#522)
  • 929de12 :arrow_up: Update Node.js to v12.11.0 (#528)
  • e69b697 :arrow_up: Update dependency react-router-dom to v5.1.0 (#523)
  • 278156b :arrow_up: Update types
  • d7c4b7b :sparkles: Support input_select (#530)
  • 4fa6ebd :ambulance: Handle bad chart data
  • 570c6c8 :arrow_up: Update react monorepo to v16.10.0 (#531)
  • f9fa5e0 :arrow_up: Update dependency react-router-dom to v5.1.1 (#532)
  • 2f587b1 Expand entity card (#533)
  • 71b80aa :sparkles: New color wheel
  • 38afbd1 :hammer: Add missing card move logic
Full Changelog
Just tried long press on my phone and it didnā€™t show up for info. Using Android
hi, I cannot update from 1.2.0 to 2.2.0.
I donā€™t see 2.2.0 on the repo list. Is there another repo URL?
The released code is at https://github.com/timmo001/home-panel/releases, and thereā€™s a 2.2.0 tag on Docker Hub as well: https://hub.docker.com/r/timmo001/home-panel.
I thought it might be available on add-on store.
Thanks for the links.
Home Panel v2.2.1 :tada:
GitLab CI
A few layout fixes in this one. Long press fixed for touch devices, as well as rework on sizing with smaller devices. :iphone:
Changes
  • 1d15ff8 :arrow_up: Update react monorepo to v16.10.1 (#534)
  • ab94677 :arrow_up: Update dependency feathers-nedb to v5.0.2 (#536)
  • 653b990 :arrow_up: Update dependency nodemon to v1.19.3 (#537)
  • a060ca1 :hammer: Make card title and state text not selectable
  • 1a972f6 :fire: Rework grids to fix smaller screens
  • 9bdb8ba :hammer: Add userSelect to climate text
  • f86c9a0 :hammer: Cleanup
  • eedc9c7 :ambulance: Fix long press for touch devices
  • b714108 :ambulance: Fix group scrolling from rework
  • 695f103 :hammer: Fix position and backdrop of expanded card
  • 55c0f8d :hammer: Improve edit card experience with smaller devices
Full Changelog
