Home Panel - A web frontend for controlling the home
Home Panel
Build Status
GitHub Release Project Stage License
GitHub Activity Project Maintenance
Docker Version Docker Pulls
Supports armhf Architecture Supports aarch64 Architecture Supports amd64 Architecture Supports i386 Architecture
Buy me a coffee
A web frontend for controlling the home. Integrates with
Home Assistant as an additional frontend.
banner
Features
  • Supports Home Assistant entities, cameras, news feeds, iframes and
    more.
  • Made for touch screens and desktops with a sideways scrolling Material Design
    interface.
  • Fully customizable interface.
  • Custom theme support.
  • Full in application configuration UI.
Documentation / Setup
Setup and configuration for the app is available here
Links
Support / Discussion
Code of Conduct
Contribution Guidelines
License
Screenshots
Release 0.4.0
Full Changelog
Changed
  • :sparkles: add link support (#17)
  • :sparkles: radio support (#15)
  • :books: update docs
  • :arrow_up: update packages
This release adds the requirement of https://github.com/timmo001/home-panel-api
HASS.io Addon
Now I am happy with security and the app has a decent amount of features, I am going to look into creating an addon for hass.io
See progress on this on the issue page:
https://github.com/timmo001/home-panel/issues/25
Release 0.4.1
Full Changelog
Changed
  • :rocket: fix ci build
  • :books: change to mkdocs
  • :boat: shrink container by cleaning yarn cache
  • :fire: fix missing entity or missing config
Hi @timmo001 ,
SSL is mandatory? tried to install with flag REACT_APP_HASS_SSL=ā€˜false’ and after 30 secs, the docker stops running
Hi @revin,
SSL isn’t mandatory, however is recommended when using Home Panel in a production environment
Can you post the logs?
If using docker-compose:
docker-compose logs -f
or docker:
docker logs -f NAME_OF_CONTAINER
Hi @timmo001,
The detail error is:
nginx: [emerg] BIO_new_file("/ssl/fullchain.pem") failed (SSL: error:02FFF002:system library:func(4095):No such file or directory:fopen('/ssl/fullchain.pem', 'r') error:20FFF080:BIO routines:CRYPTO_internal:no such file)
Here you have the fulllog:
https://pastebin.com/mDmrHv1E
It seems that I don’t write the correct syntax to avoid SSL. This is the full docker instruction:
docker run -d --name="panel" -e REACT_APP_HASS_HOST='192.168.1.210' -e REACT_APP_HASS_PASSWORD='API_PASSWORD' -e REACT_APP_HASS_SSL='false' -p 8234:443 -v /docker/panel/ssl:/ssl -v /docker/panel/config.json:/usr/src/app/config.json timmo001/home-panel
Thanks!
Ah glad you managed to fix it.
I will add some examples for those who don’t want to use ssl to the docs
Hi @timmo001
Sorry but english it’s not my native language and I didn’t explain well.
I wanted to explain that the sintax that I’m using it’s not the correct to avoid SSL. I’m still not able to start the docker.
I also tried with the -e REACT_APP_HASS_SSL='false' option but I get the same error.
Looks like there is an issue with the nginx config file that is copied on build. I have found the issue in the dockerfile and and fixed it.
This will be available in the next release, coming in the next few hours. Thanks for the heads up @revin!
Good news!
Thanks @timmo001
Release 0.4.2
Full Changelog
Changed
  • :hammer: fix radio hidden position
  • :hammer: fix theme selection
  • :sparkles: added screenshots and more examples to docs
  • :rocket: temporary fix for #28
  • :boat: fix docker for non ssl setups
  • :books: update docs to include unsecure examples
Hi @timmo001
Just Installed 0.4.3. Specifying -p 8234:443 option, I can’t connect to the app. I’ve used the --net=host option and now is able to bind to port 80
now I can see the app but I’m stuck on ā€œattemting to connect to Hassā€.
Is it possible to see the apps logs? with docker logs only get the info until the nginx start process.
Thanks!
I’ve been working on it and now I’m able to start on 8234 port without --net option but I’m stuck on ā€œattemting to connect hassā€
I 've tried with -e REACT_APP_HASS_HOST='192.168.1.210' and -e REACT_APP_HASS_HOST='192.168.1.210:8123' but i get the same error.
Hi @revin,
If you are using Chrome, you can press F12 to bring up the developer console, which will give you any errors that arise.
You might want to try setting REACT_APP_HASS_SSL='true' since the secure option is likely the default with HASS now
You pointed on th right direction
WebSocket connection to 'wss://192.168.1.210:8123/api/websocket?latest' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
Will try later to generate a certificate and build with SSL option. I’d prefer to stay out SSL configs as I manage them from another nginx and FW.
Hope the hassio addon Is ready soon
Release v0.4.4
Full Changelog
Changed
  • :arrow_up: upgrade packages
  • :hammer: remove redundant code
  • :boat: remove useless build step
  • :boat: add api to compose file
  • :framed_picture: optimised images
Keep an eye on the issue page for updates on the HASS.io addon:
Release v0.4.5
Full Changelog
Changed
  • :hammer: allow for hassio ws proxy
This is a small change to allow for the use of hassio’s websocket proxy in the effort to create the hassio addon
Any chance of making this work with a non-SSL HomeAssistant setup? I’m getting the same issue as above where it can’t get past ā€œAttempting to connect to HASSā€¦ā€
Checking in the JS Console I see it fails to connect to wss://…
Here’s the logfile from docker, as you can see, the build realizes I don’t want the SSL config, but in the actual page code, the check of process.env.REACT_APP_HASS_SSL still seems to return true.
Copy disabled SSL nginx config,
Copy config..,
Build app..,
yarn run v1.7.0,
$ react-scripts build --production,
Creating an optimized production build...,
Compiled successfully.,
File sizes after gzip:,
  213.59 KB  build/static/js/main.8047b977.js,
  20.91 KB   build/static/css/main.12aa7665.css,
The project was built assuming it is hosted at the server root.,
You can control this with the homepage field in your package.json.,
For example, add this to build it for GitHub Pages:,
  "homepage" : "http://myname.github.io/myapp",,
The build folder is ready to be deployed.,
You may serve it with a static server:,
  yarn global add serve,
  serve -s build,
Find out more about deployment here:,
  http://bit.ly/2vY88Kr,
Done in 37.69s.,
Move build files to html directory..,
Run nginx server..,
