I am loving this front end and iâm trying to personlise it further. You mention in the docs that you can add pages, I can get pages added, but I cant work out how to make three pages and then put cards/items inside the pages. e.g one page called âscenesâ with all my scenes on it, one page called âhomeâ with all the lights and switches and a last page called âcamerasâ with all my camera feeds on it. I just end up with all the cards on one page and all the other pages empty. Ive tried adding code for a page, then item code, then cards, then another page etc, but that doesnt work. Any help would be appreciated!
I have created a couple more pages named âfloorplanâ and âmapâ. I want to see if floorplan can have one picture of my floor plan that fills the screen, just a simple jpg showing the locations of everything and their names. On the map page, I would like the device tracking map that hassio has to show where everyone is to fill the screen. Is that do-able? Do I set them up as cameras and provide the links in the url entity?
@timmo001 thanks for the add-on really love the simplicity of this.
I have a few problems, didnât want to raise it as issues as I am not sure if its me being stupid!
Iâve got two hue RGB lights in a room, when I long press on one of the lights it gives me the colour selection, however when I long press on the second it just gives me the brightness and colour temp:
Is there anyway to have more options around colour choices and also have colour temperature for the lights that provide options for colours? much like the options on offer in the main HASSio interface:
Absolutely helped. I had forgotten that I took out the weather platform setup when I moved to Lovelace and started using a custom card. After uncommenting it out, I set it as the entity_id and used your dimensions and looks perfect. Thank you!
This should be specific to your lights and whether they support colors or not. If you can let me know the component you use and I can try to verify that it is supported as I have not seen a light component without color support. No promises though, as I will likely not be able to test it without having those lights/component set up in my own HA instance.
I did try to use different color wheels like the one on HA, but I decided against it on this project since it is aimed at touch interfaces and none of the wheels/pickers I found were mobile friendly
If you set the groupâs width to span across the page and then set the card(s) width and height to the same, you should be able to fill the screen using an iframe or image:
Yep the lights support colour, I am using the hue component. The colour component works on one bulb but not the other, they are the same model bulb.
Both colour selections work in the Main HAASio dashboard, so its a bit odd.
Reference to the colour choices, makes sense with that disunion and come to think of it youâre right it would be easier.
Is there any way that I can change which colours are displayed instead then?
Thanks Timmo, but as I stated in the original post I wasnât talking about the header. No worries though as @nickcj gave me the answer and I have it running. Thanks!
Hey Tim,
In some of the screenshots there are larger cards for what look to be climate controls (Central Heating). Any advice on how I can implement these? Thanks,
Em.
If you want the card to look the exact same, you can set the width and the height to 2, so the card is 2x2. This can be any size though so play around and see what you like
