Home-panel- problems
Hi There.
I have installed Home Panel on Hasios, all installed correctly, config save as non ssl.
I can get to the url http:// myhassip:3234 and get: “Home Panel API is active!. This is the correct location for the API of Home Panel. Use this to test that the backend is active.
This is not the main application. Please check the docs if you do not know how to access this.”
I can log onto Home Panel from within home assistant only.
Well for the life of me I cant find anywhere in the documentation how to get to the logon screen from the browser IP address.
Any help would be appreciated.
Thanks John
