Home Security Automation (Arlo) solution - Can I consolidate the Automations?
Hi there,
after the first experience with automation I now tried to automate my home security Arlo system.
I’d like to share my working solution and ask about your opinion about improvements.
[1] Is it possible to consolidate this rule-set into just one rule?
[2] Do you see issues the way I implemented it?
How it’s supposed to work:
  • If I leave home → arm
  • If I come home & it’s between 8 am and 10 pm → disarm
  • When it get’s 10 pm & not already armed → arm
  • When it get’s 8 am & I am at home → disarm
I created 4 automation rules covering it:
alias: Arm Arlo cameras when leaving
description: ''
  - platform: state
    entity_id: person.andi
    to: not_home
condition: []
  - service: alarm_control_panel.alarm_arm_away
      entity_id: alarm_control_panel.aarlo_arlo_huhn
  - service: notify.mobile_app_sm_g973f
      message: ''
      title: Arlo ON (Zone Away)
mode: single
alias: Disarm Arlo cameras when coming home
description: ''
  - platform: state
    to: home
condition:
  - condition: time
    after: '08:00:00'
    before: '22:00:00'
  - service: alarm_control_panel.alarm_disarm
      message: ''
      title: Arlo OFF (Zone Home)
mode: single
alias: Arm Arlo cameras in the evening
description: ''
  - platform: time
    at: '22:01'
  - platform: homeassistant
    event: start
  - platform: event
    event_type: automation_reloaded
condition:
  - condition: template
    value_template: '{{ states(''alarm_control_panel.aarlo_arlo_huhn'') != ''armed_away'' }}'
  - condition: time
    after: '22:00:00'
    before: '08:01:00'
      message: ''
      title: Arlo ON (Abend)
mode: single
alias: Disarm Arlo cameras in the morning
description: ''
  - platform: time
    at: '08:01'
    event: start
  - platform: event
condition:
  - condition: state
    state: home
  - condition: time
    after: '08:00:00'
    before: '22:01:00'
      message: ''
      title: Arlo OFF (Morgen)
mode: single
(2) If it’s working, then there are no issues :slight_smile: .
(1) You could, yes — the obvious way would be to combine all your triggers, then use choose under the action block, with the conditions from each of your four automations in each choose block:
Would that be any better or clearer, though?
If you do go that way, add an id to your automation, then you can use the excellent automation debugging tool.
Thank you! Think you are right… maybe it’s better having it clearer than more compact. Thanks for the article, interesting possibilities anyway.
