Hi good evening everyone, hope that you all are well and safe…
I want to transition from ST to HA, so where should i start? Where can i get the HA Hub?
I have low knowledge about coding, although i can read and use videos, but if any of you want to do a step to step process, I won’t get mad :P…
The “hub” is whatever hardware you want to run it on (Pi3 or better). You can buy the likes of the Home Assistant Blue if you want to, but it’s not required.
