I am getting the following errors (it works with homeassistant-0.61.0):
/srv/hass/bin/hass --script check_config
2018-01-17 22:04:17 INFO (Thread-2) [homeassistant.config] Upgrading configuration directory from 0.60.0 to 0.61.1
2018-01-17 22:04:17 INFO (Thread-2) [homeassistant.config] Migrating old system configuration files to new locations
2018-01-17 22:04:18 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.history. Make sure all dependencies are installed
File “/srv/hass/lib/python3.5/site-packages/homeassistant/loader.py”, line 142, in get_component
module = importlib.import_module(path)
File “/usr/lib/python3.5/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 986, in _gcd_import
File “”, line 969, in _find_and_load
File “”, line 958, in _find_and_load_unlocked
File “”, line 673, in _load_unlocked
File “”, line 673, in exec_module
File “”, line 222, in _call_with_frames_removed
File “/srv/hass/lib/python3.5/site-packages/homeassistant/components/history.py”, line 20, in
from homeassistant.components.http import HomeAssistantView
File “/srv/hass/lib/python3.5/site-packages/homeassistant/components/http/init.py”, line 35, in
from .static import (
File “/srv/hass/lib/python3.5/site-packages/homeassistant/components/http/static.py”, line 9, in
from yarl import unquote
ImportError: cannot import name ‘unquote’
- Setup failed for frontend: Component not found.
- Component not found: config
- Setup failed for config: Component not found.
- Component not found: http
- Setup failed for http: Component not found.
- Component not found: automation
- Setup failed for automation: Component not found.
- Component not found: google_assistant
- Setup failed for google_assistant: Component not found.
- Component not found: logbook
- Setup failed for logbook: Component not found.
- Component not found: conversation
- Setup failed for conversation: Component not found.
- Component not found: tts
- Setup failed for tts: Component not found.
- Component not found: input_select
- Setup failed for input_select: Component not found.
- Component not found: device_tracker
- Setup failed for device_tracker: Component not found.
- Component not found: scene
- Setup failed for scene: Component not found.
Successful config (partial)
Some relevant parts of the config:
001 config:
003 homeassistant:
…172 # Enables the frontend
173 frontend:
174186 # Checks for available updates
187 updater:
188
189 # Discover some devices automatically
190 discovery:
191
192 # Allows you to issue voice commands from the frontend in enabled browsers
193 conversation:
194
195 # Enables support for tracking state changes over time.
196 history:
197
198 # View all events in a logbook
199 logbook:
200
201 # Track the sun
202 sun:
203
