Homeassistant 2024.7.0 crashed with logs
Setup
HA VM on Synology NAS
Version 2024.6.4
Hi
I’m upgrading from 20024.6.4 to 2024.7.0 official release when Homeassistant crashed with the following logs
2024-07-04 14:26:43.672 WARNING (MainThread) [homeassistant.components.hassio.handler] Found incompatible HTTP option 'server_host'. Watchdog feature disabled
2024-07-04 14:26:50.556 ERROR (MainThread) [frontend.js.latest.202407030] Uncaught error from Firefox 127.0 on Windows 10
TypeError: t is undefined
/local/lib/tingle/dist/tingle.min.js:1:117
/local/lib/tingle/dist/tingle.min.js:1:121
2024-07-04 14:26:51.015 ERROR (MainThread) [frontend.js.latest.202407030] Uncaught error from Firefox 127.0 on Windows 10
Error: Failed to execute 'define' on 'CustomElementRegistry': the name "weather-card" has already been used with this registry
3900/</window.CustomElementRegistry.prototype.define (src/scoped-custom-element-registry.js:44:14)
/local/custom-lovelace/weather-card/weather-card.js:535:16
Error: Failed to execute 'define' on 'CustomElementRegistry': the name "upcoming-media-card" has already been used with this registry
/hacsfiles/upcoming-media-card/upcoming-media-card.js:468:16
2024-07-04 14:26:51.016 ERROR (MainThread) [frontend.js.latest.202407030] Uncaught error from Firefox 127.0 on Windows 10
Error: Failed to execute 'define' on 'CustomElementRegistry': the name "swipe-card" has already been used with this registry
/local/custom-lovelace/swipe-card/swipe-card.js:1:173638
/local/custom-lovelace/swipe-card/swipe-card.js:1:121
/local/custom-lovelace/swipe-card/swipe-card.js:1:125
Error: Failed to execute 'define' on 'CustomElementRegistry': the name "vertical-stack-in-card" has already been used with this registry
/hacsfiles/vertical-stack-in-card/vertical-stack-in-card.js:185:16
Error: Failed to execute 'define' on 'CustomElementRegistry': the name "swiss-army-knife-card" has already been used with this registry
/hacsfiles/swiss-army-knife-card/swiss-army-knife-card.js:971:5570
I’m in the process for restoring to last known working config - Version 2024.6.4
I had to remove the ‘trusted_networks’ node from configuration.yaml to ‘fix’ the error.
Thanks for the suggestion.
I commented out the ‘trusted_networks’ section, rebooted ha then made a full backup before updating to 2024.7.1.
Applied the update. Upon reboot same error occurred :disappointed: .
Currently restoring back to previous config.
Hi, i have the same (similiar) problem.
Can not update HA because then Recovery mode is activated.
Nobody any suggestions pls.?
thx
