Hello Guys,
I have a HomeAssistant container installed and working. I have many Shelly Pro 4PM devices, all of my power sockets, lights, heating connected to them. I also have a Shelly H&T device what reports the temperature and humidity, it works well. What I would like to achive to turn off the heating (switch the correct Shelly Pro 4PM entity) if the temperature is above 25 celsius, and turn it on when the temperature is below 23 celsius. So I created 2 automation via the WebUI:
For turning off:
alias: Street bedroom heating off
description: Turn off the heating if the temperature is above 25 celsius
triggers:
- trigger: numeric_state
entity_id:
- sensor.shellyhtg3_84fce639d0d8_temperature
above: 25
conditions: []
actions:
- action: switch.turn_off
metadata: {}
data: {}
entity_id: switch.f_utcai
mode: single
For turning on:
alias: Street bedroom heating on
description: Turn on the heating if the temperature is above 23 celsius
triggers:
entity_id:
below: 23
conditions: []
actions:
- action: switch.turn_on
metadata: {}
data: {}
mode: single
Looks like this does not trigger at all, but I see the temperature is around 27-28 celsius, reported back correctly by H&T device in every 5 minutes. If I click to “Run actions” then it will do the switch and turn off the heating, so I guess the action part is correct. As you can see, I don’t have conditions, hence the trigger should have some problems, but if I am correct, then idk how to debug this, because I don’t see anything under Trace. I created this 2 automations via web, so I didn’t touched or applied anything to YAML, this is the pure web based config.
Maybe somebody have experience with this kind of automation and have an idea how can I move forward? I already disabled/enabled the automation, restarted the whole home assistant container as well.
