Hi
I have one backend with MQTT-broker and a lot of clients:
backend:
- RPI-87:
- RaspberryPi 4, running homeassistant on docker
- add-on: Mosquitto broker V5.1
frontend(s)
- RPI-82, homeassistant in docker connected to backend
- RPI-83, homeassistant in docker connected to backend
- RPI-86, homeassistant in docker connected to backend
- DEB-17, homeassistant in docker connected to backend
- MQTT-explorer
- node-red
As you can see: a lot of clients connected to the same MQTT broker.
Yesterday, it is the second time that
- the homeassistant clients can connect to broker (I can see incomming connections in the log of my broker)
- the homeassistant clients can not see the devices (defined on the mqtt-broker) anymore
- the other clients (MQTT-Assistant, node-red, CLI mosquitto_sub, etc… still can connect to MQTT-broker and see messages published by the devices.
So my solution now:
- stop MQTT broker
- delete mosquitto.db on /usr/share/hassio/addons/data/core_mosquitto/mosquitto.db
- restart MQTT broker
- restart the devices that produce the mqtt messages (in my case: zigbee2mqtt, ems-esp, …)
The first time, I thought this was a hickup, however, it is the second time now in a timespan of +/- 1 month.
Anybody experiences the same problems?
Is there a solution for this?
kind regards,
Bart
