I am installing HomeAssistant on Debian 12 Bookworm testing, on Mac mini M1.
I am using standard docker installation.
When searching for this error it was mentioned before with QNAP. And I have the versions of docker and libseccomp2 above the requirement.
Any suggestions on how this could be fixed?
Here is the log:
<jemalloc>: Unsupported system page size
Fatal Python error: _PyRuntimeState_Init_impl: memory allocation failed
Python runtime state: unknown
[17:33:02] INFO: Home Assistant Core finish process exit code 1
[17:33:02] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services successfully started
s6-rc: info: service legacy-services: stopping
[17:33:03] INFO: Home Assistant Core finish process exit code 256
[17:33:03] INFO: Home Assistant Core finish process received signal 15
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
[17:33:32] INFO: Home Assistant Core finish process exit code 1
[17:33:32] INFO: Home Assistant Core service shutdown
[17:33:33] INFO: Home Assistant Core finish process exit code 256
[17:33:33] INFO: Home Assistant Core finish process received signal 15
