nikno
(Niklas)
March 8, 2019, 6:34am
1
Today I checked my home-assistant.log and found a 20 something warnings of these kinds:
WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 66.249.82.x
x being 3 different digits.
Checking the IP Information it seems like these IP addresses are owned by Google.
Some day ago I enabled the new Google Home component, is this related or just a coincident?
I am on 0.88.2.
callifo
(Callifo)
March 8, 2019, 6:46am
2
Yes, that is a similar range that makes API calls to do Google Assistant functions. Is the API key you supplied to it wrong?
Vennerberg
(Patrik Vennerberg)
3
Probably, disable the component for a few days to see if it goes away. If it does, you’ll know.
nikno
(Niklas)
March 8, 2019, 12:09pm
4
Hmm…
I haven’t supplied any API keys to set up the Google Home component, it is not specified in the documentation.
https://www.home-assistant.io/components/googlehome/
callifo
(Callifo)
March 8, 2019, 12:55pm
5
Sorry, meant Google Assistant, not Google Home.
GA exposes your HA to allow Google to send it commands.
nikno
(Niklas)
March 18, 2019, 3:44pm
6
The warnings just appeared that day, strange.
Anyway I have now removed the configuration for the Google Home in HA, wanted to use it for the Bluetooth presence detection, but it just went on populating my known_devices.yaml, so disabled it after 400+ devices found…
