I’ve run into some problems with my install. Suddenly I could no longer log into it, and discovered I could log in just fine using incognito mode. Found the above error in the logs, so I tried removing “old” entries from the auth file (per some threads I found on google). The problem is, it still doesn’t work from my regular browser…
Any idea on how to fix this?
