OK I’m completely at a lost so far, I have no idea what to do next… I’ve tried many things and still no joy in getting my HA to start with the new SQLlite…
When I look at python env its report 3.38. but somehow hass is still picking up 3.7… HELP?
❯ which python3
~/homeassistant/bin/python3
❯ python3
Python 3.9.9 (main, Jun 3 2022, 08:50:20)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-44)] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import sqlite3
>>> sqlite3.sqlite_version
'3.38.2'
But on the logs:
2022-06-03 09:00:43 ERROR (Recorder) [homeassistant.components.recorder.util] Version 3.7.17 of SQLite is not supported; minimum supported version is 3.31.0. Starting with Home Assistant 2022.6 this prevents the recorder from starting. Please upgrade your database software
2022-06-03 09:00:43 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.
I have the same problem like you. However, I run HA on an old Mac with Sqlite3 version 3.19.3. A newer version of sqlite3 was installed on macOS using homebrew. After creating the python virtual environment, I specified a PYTHONPATH, where to find the homebrew version of sqlite3 and within the python virtual environment, I do see the new version:
(venv) homeassistant2022> sqlite3 --version
3.38.5 2022-05-06 15:25:27
(venv) homeassistant2022> echo $PYTHONPATH
/usr/local/Cellar/sqlite/3.38.5/bin/sqlite3
(venv) homeassistant2022> python
Python 3.9.13 (main, Jun 11 2022, 14:28:39)
[Clang 10.0.0 (clang-1000.11.45.5)] on darwin
>>> import sys
>>> for path in sys.path:
... print(path)
/Users/thomas/.pyenv/versions/3.9.13/lib/python39.zip
/Users/thomas/.pyenv/versions/3.9.13/lib/python3.9
/Users/thomas/.pyenv/versions/3.9.13/lib/python3.9/lib-dynload
/Users/thomas/Applications/homeassistant2022/venv/lib/python3.9/site-packages
>>> import sqlite3
'3.19.3'
Unfortunately, I am not even that far as you were, because when I import sqlite3 in python console, I even get the old version 3.19.3.
