Hi
Today, after a long pause, I decided to update my Home Assistant. My setup runs fully dockerised using Container Station on a QNAP NAS. As I had not restarted the NAS for a number of weeks I also took the opportunity to update all apps on the NAS including Container Station.
When I restarted, the MariaDB which is also dockerised, would not start. After 2 hours back and forth, I decided to create a new DB based on MYSQL and eventually Home Assistant was back up and running. That is except for a few irritating issues.
I have a number of mobile devices that I use for device tracking and apart from one (my main device) they have all initialised with no problem. The error that I get for the my device is shown below.
Logger: homeassistant.config_entries
Source: config_entries.py:402
First occurred: 8:12:10 PM (1 occurrences)
Last logged: 8:12:10 PM
Error setting up entry Pixel 6a for mobile_app
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 402, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/mobile_app/init.py”, line 104, in async_setup_entry
webhook_register(hass, DOMAIN, registration_name, webhook_id, handle_webhook)
File “/usr/src/homeassistant/homeassistant/components/webhook/init.py”, line 53, in async_register
raise ValueError(“Handler is already defined!”)
ValueError: Handler is already defined!
Any ideas what the problem could be?
