Im using:
- raspberry pi 3
- Raspbian stretch 4.14
- PiHOLE
- Homeassistant 0.87 - installed usuing the virtual enviroment
- Lets Encrypt - cerbot thingy
I NEED HELP setting LIGHTTPD with HASS + PiHOLE and SSL so I can access my HASS installition from the outside through httpS
Notes and test:
- -I have my IP being updated so traffic is always sent to my IP, etc. - I can access from outside and inside my network
- -Modem is redirecting 80, 443 to Pi to serve pages
- -Im able to access using the IP and the port 8123
- -Im able to reach the pages set within lighhttp (pihole and other junk I set)
- -Im running my lighttpd with HTTPs and enforcing redirection at the conf file level from 80 to 443
- -I read that lighttpd does not work with proxy_pass and ssl like apache (I have an example of how my proxypass was working with apache here: Homeassistant does not work enabling ssl - #25 by aelg305
my HASS configuration.yaml
http:
base_url: mymainsite.com # under this one, I dont know if I should include the port, since mymainsite.com points to an actual page or use an alias... like hass.mymainsite.com)
ssl_certificate: !secret client_cert # I have this currently commented since its not working)
ssl_key: !secret client_key # I have this currently commented since its not working)
use_x_forwarded_for: True
ip_ban_enabled: True
login_attempts_threshold: 2
trusted_proxies:
- 127.0.0.1
- ::1
I added the follwing to my lighttp.conf (external.conf - since pihole creates one and it gets reset/modified everytime pihole its updated…just to not lose my config)
The following code set for the SSL:
$SERVER["socket"] == ":443" { ssl.engine = "enable" ssl.ca-file = "/etc/letsencrypt/live/mymainsite.com/chain.pem" ssl.pemfile = "/etc/letsencrypt/live/mymainsite.com/combined.pem" ssl.honor-cipher-order = "enable" ssl.cipher-list = "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4" ssl.use-compression = "disable" setenv.add-response-header = ( "Strict-Transport-Security" => "max-age=63072000; includeSubDomains; preload", "X-Frame-Options" => "DENY", "X-Content-Type-Options" => "nosniff" ) ssl.use-sslv2 = "disable" ssl.use-sslv3 = "disable" ssl.dh-file = "/etc/ssl/certs/dhparam.pem" ssl.ec-curve = "secp384r1" }
the following code would force HTTP to HTTPS under lighttpd
$SERVER["socket"] == ":80" { url.redirect = ( "^/(.*)" => "https://mymainsite.com/$1" ) }
