I get this exception in docker-compose and i cant explain why. It worked for weeks now and I only adjusted something at the config for other compose service and not on homeassistant itself…
Anyways, It seemed I heavily screwed up and possible lost everything in homeassistant - maybe somebody can help with this… but it seems quite hopeless…
The homeassistant container was the most stable container I’ve ever used…
image: homeassistant/home-assistant:stable
services:
homeassistant:
container_name: homeassistant
depends_on:
- proxy
networks:
- hass_network
dns:
- ${IP_DNS}
- 8.8.8.8
environment:
- VIRTUAL_HOST=${SUBDOMAIN1}.DOMAIN.de
- LETSENCRYPT_HOST=${SUBDOMAIN1}.DOMAIN.de
- [email protected]
volumes:
- ./proxy/certs:/config/ssl
- /hass/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
- /library:/media
- /hass/homeassistant/hass-brematic/custom_components/brematic:/config/custom_components
ports:
- 8123:8123
restart: unless-stopped
File "/usr/src/homeassistant/homeassistant/__main__.py", line 64, in get_arguments
import homeassistant.config as config_util
File "/usr/src/homeassistant/homeassistant/config.py", line 15, in <module>
from awesomeversion import AwesomeVersion
ImportError: cannot import name 'AwesomeVersion' from 'awesomeversion' (/usr/local/lib/python3.9/site-packages/awesomeversion/__init__.py)
[finish] process exit code 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
File "/usr/local/lib/python3.9/runpy.py", line 197, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.9/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 331, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 281, in main
args = get_arguments()
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
sys.exit(main())
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
sys.exit(main())
