HomeAssistant container does not recognize built-in intents
Hi, I have configured home assistant as docker container and rhasspy container.
Custom intents works fine (intent_script: in configuration.yaml) but built-in intents are not recognized.
This is the home assistant error log.
2022-11-20 15:50:11.120 ERROR (MainThread) [aiohttp.server] Error handling request
homeassistant  | Traceback (most recent call last):
homeassistant  |   File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
homeassistant  |     resp = await request_handler(request)
homeassistant  |   File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
homeassistant  |     resp = await handler(request)
homeassistant  |   File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
homeassistant  |     return await handler(request)
homeassistant  |   File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
homeassistant  |   File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
homeassistant  |   File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
homeassistant  |   File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware
homeassistant  |   File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
homeassistant  |   File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
homeassistant  |     result = await result
homeassistant  |   File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
homeassistant  |     result = await method(view, request, data, *args, **kwargs)
homeassistant  |   File "/usr/src/homeassistant/homeassistant/components/intent/__init__.py", line 72, in post
homeassistant  |     intent_result = await intent.async_handle(
homeassistant  |   File "/usr/src/homeassistant/homeassistant/helpers/intent.py", line 64, in async_handle
homeassistant  |     raise UnknownIntent(f"Unknown intent {intent_type}")
homeassistant  | homeassistant.helpers.intent.UnknownIntent: Unknown intent HassShoppingListAddItem
Same issue.
Logger: aiohttp.server
Source: /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py:403
First occurred: 6:53:07 PM (1 occurrences)
Last logged: 6:53:07 PM
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 227, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
  File "/usr/src/homeassistant/homeassistant/components/intent/__init__.py", line 252, in post
  File "/usr/src/homeassistant/homeassistant/helpers/intent.py", line 86, in async_handle
homeassistant.helpers.intent.UnknownIntent: Unknown intent HassGetWeather
Did you figure this out? I’m getting the same issue.
Just installed 2024.7, same Issue here, AFAIK I’ve not done anything that would make the built-in intents unknown
:woman_shrugging:
