- Guys, why do I get an error when I execute this program
program:pip3 install homeassistant==2023.3.3
ERROR: Could not find a version that satisfies the requirement homeassistant==2023
ERROR: No matching distribution found for homeassistant==2023.3
Your problem is that you skipped right past the part where it says you need Python 3.10
The simplest solution is to use Docker (ideally with Compose).
Thanks, brother.
