Homeassistant destroys the network connection
Hey Guys,
on my Raspi 4 4GB with the latest Bullseye i´ve at least problems with my network connection all 7-14 days.
Last Night the network connection is lost and when i check the syslog starts here the issue:
Nov 25 01:02:05 raspberry-sh addon_core_deconz[688]: 01:02:05:338 ZCL attribute report 0x04CF8CDF3C7E5039 for cluster: 0xFCC0, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
Nov 25 01:02:06 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:06.069 ERROR (MainThread) [homeassistant.components.shelly] Error fetching Shelly 1PM+ #01 Balkonkraftwerk data: Device disconnected: DeviceConnectionError(DeviceConnectionError(ClientConnectorError(ConnectionKey(host='192.168.12.25', port=80, is_ssl=False, ssl=None, proxy=None, proxy_auth=None, proxy_headers_hash=-4168329543384563354), OSError(113, "Connect call failed ('192.168.12.25', 80)"))))#033[0m
Nov 25 01:02:06 raspberry-sh addon_core_deconz[688]: 01:02:06:791 ZCL attribute report 0xA4C138779347A295 for cluster: 0x0702, ep: 0x01, frame control: 0x18, mfcode: 0x0000
Nov 25 01:02:07 raspberry-sh homeassistant[688]: #033[33m2022-11-25 01:02:07.422 WARNING (MainThread) [custom_components.xiaomi_gateway3.core.mini_miio] 192.168.12.252 | Device offline#033[0m
Nov 25 01:02:08 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:08.644 ERROR (MainThread) [custom_components.xiaomi_miot.switch] Cam01 (S_Wlan_01)(chuangmi.plug.hmi206): Got MiioException while fetching the state: Unable to discover the device 192.168.12.81, mapping: {'switch.on': {'siid': 2, 'piid': 1}, 'switch.temperature': {'siid': 2, 'piid': 2}, 'indicator_light.on': {'siid': 3, 'piid': 1}}, max_properties: 10/3#033[0m
Nov 25 01:02:08 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:08.647 ERROR (MainThread) [custom_components.xiaomi_miot.switch] Raspberry 4+ HA (S_Wlan_00)(chuangmi.plug.hmi206): Got MiioException while fetching the state: Unable to discover the device 192.168.12.80, mapping: {'switch.on': {'siid': 2, 'piid': 1}, 'switch.temperature': {'siid': 2, 'piid': 2}, 'indicator_light.on': {'siid': 3, 'piid': 1}}, max_properties: 10/3#033[0m
Nov 25 01:02:08 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:08.650 ERROR (MainThread) [custom_components.xiaomi_miot.light] Mi Steuerzentrale(lumi.gateway.mieu01): Got MiioException while fetching the state: Unable to discover the device 192.168.12.253, mapping: {'light.on': {'siid': 4, 'piid': 0}, 'alarm': {'siid': 3, 'piid': 1}, 'alarm.volume': {'siid': 3, 'piid': 2}, 'gateway.guard_mode': {'siid': 2, 'piid': 0}}, max_properties: 7/4#033[0m
Nov 25 01:02:08 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:08.665 ERROR (MainThread) [custom_components.xiaomi_miot.switch] Cam03 (S_Wlan_03)(chuangmi.plug.hmi206): Got MiioException while fetching the state: Unable to discover the device 192.168.12.83, mapping: {'switch.on': {'siid': 2, 'piid': 1}, 'switch.temperature': {'siid': 2, 'piid': 2}, 'indicator_light.on': {'siid': 3, 'piid': 1}}, max_properties: 10/3#033[0m
Nov 25 01:02:08 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:08.667 ERROR (MainThread) [custom_components.xiaomi_miot.switch] Gartenhütte (S_Wlan_06)(chuangmi.plug.hmi206): Got MiioException while fetching the state: Unable to discover the device 192.168.12.86, mapping: {'switch.on': {'siid': 2, 'piid': 1}, 'switch.temperature': {'siid': 2, 'piid': 2}, 'indicator_light.on': {'siid': 3, 'piid': 1}}, max_properties: 10/3#033[0m
Nov 25 01:02:09 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:09.348 ERROR (MainThread) [custom_components.xiaomi_miot.fan] Xiaomi Fan 2 links(dmaker.fan.p18): Got MiioException while fetching the state: Unable to discover the device 192.168.12.99, mapping: {'fan.on': {'siid': 2, 'piid': 1}, 'fan.fan_level': {'siid': 2, 'piid': 2}, 'fan.mode': {'siid': 2, 'piid': 3}, 'fan.horizontal_swing': {'siid': 2, 'piid': 4}, 'fan.horizontal_angle': {'siid': 2, 'piid': 5}, 'fan.off_delay_time': {'siid': 2, 'piid': 6}, 'fan.brightness': {'siid': 2, 'piid': 7}, 'fan.alarm': {'siid': 2, 'piid': 8}, 'fan.motor_control': {'siid': 2, 'piid': 9}, 'fan.speed_level': {'siid': 2, 'piid': 10}, 'physical_controls_locked': {'siid': 3, 'piid': 1}}, max_properties: 6/11#033[0m
Nov 25 01:02:09 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:09.352 ERROR (MainThread) [custom_components.xiaomi_miot.switch] Cam02 (S_Wlan_02)(chuangmi.plug.hmi206): Got MiioException while fetching the state: Unable to discover the device 192.168.12.82, mapping: {'switch.on': {'siid': 2, 'piid': 1}, 'switch.temperature': {'siid': 2, 'piid': 2}, 'indicator_light.on': {'siid': 3, 'piid': 1}}, max_properties: 10/3#033[0m
Nov 25 01:02:09 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:09.364 ERROR (MainThread) [custom_components.xiaomi_miot.fan] Xiaomi Fan 2 Rechts(dmaker.fan.p18): Got MiioException while fetching the state: Unable to discover the device 192.168.12.98, mapping: {'fan.on': {'siid': 2, 'piid': 1}, 'fan.fan_level': {'siid': 2, 'piid': 2}, 'fan.mode': {'siid': 2, 'piid': 3}, 'fan.horizontal_swing': {'siid': 2, 'piid': 4}, 'fan.horizontal_angle': {'siid': 2, 'piid': 5}, 'fan.off_delay_time': {'siid': 2, 'piid': 6}, 'fan.brightness': {'siid': 2, 'piid': 7}, 'fan.alarm': {'siid': 2, 'piid': 8}, 'fan.motor_control': {'siid': 2, 'piid': 9}, 'fan.speed_level': {'siid': 2, 'piid': 10}, 'physical_controls_locked': {'siid': 3, 'piid': 1}}, max_properties: 6/11#033[0m
Nov 25 01:02:10 raspberry-sh hassio_dns[688]: [INFO] 172.30.32.1:54097 - 5119 "A IN r-0sjd3_k.local.hass.io. udp 41 false 512" NXDOMAIN qr,aa,rd 41 0.000338737s
Nov 25 01:02:10 raspberry-sh hassio_dns[688]: [INFO] 172.30.32.1:35648 - 46939 "A IN r-0sjd3_k.local.hass.io. udp 41 false 512" NXDOMAIN qr,aa,rd 41 0.000255053s
Nov 25 01:02:11 raspberry-sh hassio_dns[688]: [INFO] 172.30.32.1:60491 - 33570 "A IN r-0sjd3_k.local.hass.io. udp 41 false 512" NXDOMAIN qr,aa,rd 41 0.0002792s
Nov 25 01:02:11 raspberry-sh hassio_dns[688]: [INFO] 172.30.32.1:50567 - 4946 "A IN r-0sjd3_k.local.hass.io. udp 41 false 512" NXDOMAIN qr,aa,rd 41 0.000278941s
Nov 25 01:02:11 raspberry-sh addon_core_deconz[688]: 01:02:11:775 ZCL attribute report 0xA4C138779347A295 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
Nov 25 01:02:17 raspberry-sh hassio_dns[688]: [INFO] 127.0.0.1:52622 - 594 "A IN api.open-notify.org. udp 48 true 2048" NOERROR - 0 5.053504557s
Nov 25 01:02:17 raspberry-sh hassio_dns[688]: [ERROR] plugin/errors: 2 api.open-notify.org. A: dial tcp 1.1.1.1:853: i/o timeout
Nov 25 01:02:17 raspberry-sh addon_core_deconz[688]: 01:02:17:806 ZCL attribute report 0xA4C138779347A295 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
Nov 25 01:02:17 raspberry-sh homeassistant[688]: #033[31m2022-11-25 01:02:17.885 ERROR (MainThread) [custom_components.xiaomi_miot.vacuum] Saugi(roborock.vacuum.s5): Got MiioException while fetching the state: Unable to discover the device 192.168.12.10, mapping: {'vacuum.status': {'siid': 2, 'piid': 1}, 'vacuum.mode': {'siid': 2, 'piid': 2}, 'battery_level': {'siid': 3, 'piid': 1}, 'battery.charging_state': {'siid': 3, 'piid': 2}}, max_properties: 10/4#033[0m
Nov 25 01:02:18 raspberry-sh hassio_dns[688]: [INFO] 172.30.32.1:42341 - 594 "A IN api.open-notify.org. udp 37 false 512" NOERROR - 0 12.003737191s
Nov 25 01:02:18 raspberry-sh hassio_dns[688]: [ERROR] plugin/errors: 2 api.open-notify.org. A: read udp 127.0.0.1:40149->127.0.0.1:5553: i/o timeout
Nov 25 01:02:19 raspberry-sh hassio_dns[688]: [INFO] 127.0.0.1:43927 - 594 "A IN api.open-notify.org. udp 48 true 2048" NOERROR - 0 5.124730283s
Nov 25 01:02:19 raspberry-sh hassio_dns[688]: [ERROR] plugin/errors: 2 api.open-notify.org. A: dial tcp 1.0.0.1:853: i/o timeout
Nov 25 01:02:19 raspberry-sh hassio_dns[688]: [INFO] 127.0.0.1:56869 - 47531 "NS IN . udp 17 false 512" NOERROR - 0 5.125496831s
Nov 25 01:02:19 raspberry-sh hassio_dns[688]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: i/o timeout
Nov 25 01:02:20 raspberry-sh hassio_dns[688]: [INFO] 127.0.0.1:40674 - 594 "A IN api.open-notify.org. udp 48 true 2048" NOERROR - 0 5.623509864s
Nov 25 01:02:20 raspberry-sh hassio_dns[688]: [ERROR] plugin/errors: 2 api.open-notify.org. A: dial tcp 1.1.1.1:853: i/o timeout
Nov 25 01:02:20 raspberry-sh hassio_dns[688]: [INFO] 172.30.32.1:59970 - 54160 "A IN r-0sjd3_k.local.hass.io. udp 41 false 512" NXDOMAIN qr,aa,rd 41 0.000341533s
Nov 25 01:02:20 raspberry-sh hassio_dns[688]: [INFO] 172.30.32.1:51081 - 60461 "A IN r-0sjd3_k.local.hass.io. udp 41 false 512" NXDOMAIN qr,aa,rd 41 0.000312552s
Nov 25 01:02:20 raspberry-sh hassio_dns[688]: [INFO] 172.30.32.1:42341 - 594 "A IN api.open-notify.org. udp 37 false 512" NOERROR - 0 12.003691793s
Nov 25 01:02:20 raspberry-sh hassio_dns[688]: [ERROR] plugin/errors: 2 api.open-notify.org. A: read udp 127.0.0.1:58039->127.0.0.1:5553: i/o timeout
Can someone tell me whats wrong?
Maybe related?
https://community.home-assistant.io/t/problem-with-wifi-network-on-startup
