work? It’s missing the hostname or IP-address to connect to it remotely. Try with http://ww.xx.yy.zz:8123
Locally you will need to attach a monitor and a keyboard to your Pi4.
Maybe the SD card in your Pi is corrupt.
you need to be sure that you can get to the logs. It can be anything like incorrect configuration, disk full.
I hope you have installed the SSH addon or Samba. If not, connect a screen and keyboard to the RPI.
Hi there, I am someone who has been using Apple HomeKit and I had a RPi4 with Homebridge installed to get some of my devices into HomeKit. I had a few containers installed and I got HA HA as a container on that same Pi because I had a number of Zigbee devices left to me by the previous owner of my house that I had started playing with HA to integrate (successfully). I was using HA to expose some of those Zigbee plugs to HomeKit, where I still have most of my automations and only started tinkering with HA to do some more advanced automations and today HA is gone like a fart in the wind. I noticed that one of my auotmations that turns two of those aforementioned Zigbee plugs wasn’t working and so I pulled out my phone to notice all HA devices were offline in HomeKit and then I went to the HA mobile App and it cannot find my home server.
I know the Pi is working fine because I can connect to Homebridge, Scripted and WatchTower and I even tried to restart the HA container in Portainer and to no avail. Any chance I can retrieve what was lost? Is it for sure lost? I can access the terminal through the Homebridge UI if that helps me find what I’m looking for.
