I have at the moment the PRoblem that home asssitant Docker freezes.
OMV 7 on Debian 12
docker-compose:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:latest"
volumes:
- /media/wichtig/server/smarthome/homeassistant/config:/config
- /srv/dev-disk-by-uuid-7c4edeed-cf85-4693-b085-3cf0d92a7284:/config/backups
- /etc/localtime:/etc/localtime:ro
- /run/dbus:/run/dbus:ro
restart: unless-stopped
privileged: true
network_mode: host
sudo docker logs homeassistant (last hour)
2024-04-11 20:46:36.394 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:46:48.396 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:47:00.396 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:47:12.397 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:47:24.398 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:47:36.399 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:47:48.400 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:47:50.541 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:47:50.541 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:48:00.400 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:48:06.382 ERROR (Recorder) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:48:12.401 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:48:24.401 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:48:36.402 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:48:48.403 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:49:00.403 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:49:10.977 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:49:10.978 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:49:12.404 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:49:24.406 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:49:36.407 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:49:46.390 ERROR (Recorder) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:49:48.407 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:50:00.408 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:50:12.408 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:50:24.409 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:50:31.191 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:50:31.192 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:50:34.623 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:50:36.415 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:50:48.416 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:51:00.416 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:51:12.416 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:51:24.417 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:51:36.419 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:51:48.420 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:51:51.578 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:51:51.579 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:51:51.653 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:52:00.420 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:52:12.421 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:52:24.422 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:52:36.423 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:52:48.425 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:53:00.425 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:53:11.762 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:53:11.762 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:53:12.426 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:53:15.315 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:53:24.427 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:53:36.431 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:53:48.432 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:54:00.433 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:54:12.434 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:54:24.435 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:54:31.938 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:54:31.938 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:54:35.030 ERROR (Recorder) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:54:36.437 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:54:48.438 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:55:00.438 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:55:12.439 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:55:24.440 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:55:36.441 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:55:48.441 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:55:52.147 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:55:52.147 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:55:53.563 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:56:00.442 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:56:12.443 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:56:24.444 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:56:36.444 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:56:48.445 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:57:00.446 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:57:12.448 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:57:12.461 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:57:12.461 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:57:14.184 ERROR (Recorder) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:57:24.449 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:57:36.451 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:57:48.451 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:58:00.453 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:58:12.453 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:58:24.454 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:58:32.847 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:58:32.847 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:58:35.168 ERROR (SyncWorker_20) [homeassistant] Error doing job: Unclosed client session
2024-04-11 20:58:36.456 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:58:48.457 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:59:00.457 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:59:12.458 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:59:24.459 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:59:36.460 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:59:48.460 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 20:59:53.334 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Exception on post: Cannot connect to host 192.168.2.150:8088 ssl:default [Connect call failed ('192.168.2.150', 8088)]
2024-04-11 20:59:53.335 ERROR (MainThread) [aioharmony.hubconnector_websocket] 192.168.2.150: Unable to retrieve HUB id
2024-04-11 20:59:54.421 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session
2024-04-11 21:00:00.274 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.vorhop_hourly exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2024-04-11 21:00:00.461 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 21:00:12.462 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 21:00:24.463 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 21:00:36.463 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2024-04-11 21:00:48.464 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
Portainer shows it as running
(4 hours before was the last crash…)
Then I have to restart homeassistant and it’s working again.
## System Information
version | core-2024.4.1
installation_type | Home Assistant Container
dev | false
hassio | false
docker | true
user | root
virtualenv | false
python_version | 3.12.2
os_name | Linux
os_version | 6.1.0-18-amd64
arch | x86_64
timezone | Europe/Berlin
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4889
Installed Version | 1.34.0
Stage | running
Available Repositories | 1410
Downloaded Repositories | 19
</details>
<details><summary>Dashboards</summary>
dashboards | 8
resources | 11
views | 8
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 3. April 2024 um 09:54
current_recorder_run | 11. April 2024 um 21:19
estimated_db_size | 1888.96 MiB
database_engine | sqlite
database_version | 3.44.2
</details>
