Hi
I rebuilt my server and I kept on getting bad gateway 502 error.
The fix was to edit homeassistant.subdomain.conf
and change both the proxy_pass to use the local IP address of the server instead eg.
proxy_pass http://xxx.xxx.xxx.xxxx:8123;
Hopefully this helps someone
g0m
(g0m)
2
Sir, you literally just saved my ass!!!
mswsn
3
Ran into this issue as well, thanks for the tip!
Iām also here to say you just saved my ass. This should be stickied SOMEWHERE.
Many thanks, this just helped me too!
