Homeassistant fail to install on docker QNAP
Dear all,
trying to install on docker on a TS-780 pro running QTS 4.3.6 and Containerstation 2.0.957
tried to install the latest Image Vers. of Home Assistant - but installation failes with the error message “x509: certificate has expired or is not yet valid”
BUT: docker certificate is brandnew as of 2024/05/15
Idea why its not working?
Code
Fehler    2024/05/16 22:11:47    Container    admin    Failed to do background task (create, home-assistant-3)
Fehler    2024/05/16 22:11:47    Container    admin    Background task error for create home-assistant-3: error pulling image configuration: Get https://production.cloudflare.docker.com/registry-v2/docker/registry/v2/blobs/sha256/1b/1b17f5f1ee49965b74e8d86a580d7f40bf180a7dad8d49fd11d1a8d60bc8e3ac/data?verify=1715893306-FTGHr2IB7tE95vJ8raRtZ7E3nJ4%3D: x509: certificate has expired or is not yet valid
Info    2024/05/16 22:11:43    Container    admin    Start to do background task (create, home-assistant-3)
You should install HA as an App in Container Station using a Docker Compose YAML script. Here’s and example:
version: '3'
services:
  homeass:
    image: ghcr.io/home-assistant/home-assistant:2024.5.3
    restart: "no"
    network_mode: host
    environment:
      LANG: nb_NO.UTF-8
      TZ: Europe/Oslo
    volumes:
      - /share/Public/HomeAss-Config:/config
      - /share/Plex_Music:/media:ro
In the above example, change language and time zone to your own region. Then change the config path to whatever you want. The media path is optional.
Great Viking! Installation worked thanks your YAML File. But now I miss an URL to adress the installation. I tried network_mode: bridge and host. Both wont deliver an adress.
To run Home Assistant after installation, just use the IP of the server where it runs, followed by port number 8123
Example: http://192.1681.156:8123
Thanks Viking for the Portnumber - works superfine
Next and last encounter is to include the Zwave.me ZME USB Dongle, that is plugged in my QNAP into Homeassistant.
And to add: I also need to run a Mosquitto Server. The ready Image wont also install ending with an error.
Which Mosquitto image are you trying to install?
