tguett
(Tguett)
November 1, 2024, 5:12pm
1
Hallo
as log as i had only the windspeed in the configuration.yaml
everything was fine. After i added Strompreis the Windspeed
disappeared and only Strompreis is available. Can ynone help me
on this ?
Best regards
Thomas Guettler
platform: file
file_path: /config/sensor-data.txt
value_template: ‘{{ value.split(“,”)[1] }}’
unit_of_measurement: “km/h”
platform: file
file_path: /config/strompreis-data.txt
value_template: '{{ value.split(":")[1] }}'
unit_of_measurement: "Cent"
Core 2024.5.2
Frontend 20240501.1
Please format your code (all your code) correctly.
We can’t tell you if you have indentation issues, plus you’re definitely missing a -
before each platform line.
tguett
(Tguett)
November 1, 2024, 6:13pm
3
Hallo see fill Configuration.yaml File
Loads default set of integrations. Do not remove.
default_config:
logger:
default: critical
default: error
logs:
custom_components.hacs: fatal
# log level for HA core
homeassistant.core: fatal
#ssl_certificate: /config/fullchain.pem
#ssl_key: /config/privkey.pem
notify:
recorder:
purge_keep_days: 10 # Anzahl der Tage, die Daten aufbewahrt werden sollen
purge_keep_days: 180 # Anzahl der Tage, die Daten aufbewahrt werden sollen
purge_interval: 365 # Intervall in Tagen, wann alte Daten gelöscht werden
Load frontend themes from the themes folder
#frontend:
themes: !include_dir_merge_named themes
frontend:
themes:
happy:
primary-color: pink
accent-color: orange
sad:
primary-color: steelblue
accent-color: darkred
Text to speech
tts:
platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
modbus: !include modbus.yaml
tapo:
discovery: true
binary_sensor:
platform: ping
host: 8.8.8.8
count: 2
scan_interval: 300
host: 83.236.170.202
count: 2
scan_interval: 300
host: 192.168.2.23
count: 2
scan_interval: 300
host: 192.168.2.223
name: "TPLink Ping Zaehlerschrank"
count: 2
scan_interval: 300
host: 192.168.2.205
name: "TPLink Ping SAX"
count: 2
scan_interval: 300
host: 192.168.2.210
count: 2
scan_interval: 300
homeassistant:
allowlist_external_dirs:
- “/config/”
platform: file
platform: file
SOLAX CLOUD.
END OF CONFIGURATION FILE
Best regards Thomas
tguett
(Tguett)
November 1, 2024, 9:10pm
4
Hallo oki will test and let you know. Thank you Thomas Guettler
tguett
(Tguett)
November 1, 2024, 9:13pm
5
Adding the -
- platform: file
- platform: file
caused
RichardU
(Richard)
November 5, 2024, 2:09pm
6
Indentation error? Try:
- platform: file
