HomeAssistant Light after sunset via motion and light always off after time
GitHub Link Click Here
Version: 0.1
The Automation Process:
  • Switches the light on for a time X when movement is detected. But only when the sun has set far enough.
  • And if the light was switched on by something else, the light is switched off after Y minutes. (No button or similar may be specified).
What is needed
  • An entity from the domain light
  • An entity of the domain binary_sensor and Device_Class Motion
Has been tested with
  • ELTAKO EnOcean FSR14_4x (Light)
  • ELTAKO EnOcean FTS14EM (Input from motion detector)
Example
Motion
Motion detected - light on
End of movement - light off
End
Light on through something
The light was switched on. (By something)
Possibility 1: Light was switched off by something.
Possibility 2: Light is switched off after time X.
End
Otherwise
The right path is run through if it was not dark enough but the motion detector was triggered.
