I have several HACS integrations and HA issues a warning about them not being tested
domotique-hass-1 | 2023-03-11 10:15:55.721 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration toyota which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
I would like to get rid of this warning at startup time and therefore added to configuration.yml
logger:
default: warning
logs:
homeassistant.loader: error
This does not prevent the logs to still appear. Is there something else I should set up?
