I am running HA on Docker and using a VirtualBox VM for testing, pulling the same config files used on my production instance. As I don’t have a zigbee radio connected to the test rig I wanted to reduce the spurious errors in the logs so I removed the following section from my configuration.yaml
file
zha:
usb_path: /dev/ttyUSB1
database_path: /config/.storage/zigbee.db
However I still get the following items in the log:
INFO (SyncWorker_1) [homeassistant.loader] Loaded zha from homeassistant.components.zha
ERROR (MainThread) [homeassistant.config_entries] Error setting up entry /dev/ttyUSB1 for zha
File "/usr/local/lib/python3.7/site-packages/serial/serialposix.py", line 290, in _reconfigure_port
orig_attr = termios.tcgetattr(self.fd)
termios.error: (25, 'Not a tty')
<snip>
File "/usr/local/lib/python3.7/site-packages/serial/serialposix.py", line 293, in _reconfigure_port
raise SerialException("Could not configure port: {}".format(msg))
serial.serialutil.SerialException: Could not configure port: (25, 'Not a tty')
I don’t understand how the loader is still even trying this service if I removed it from the config. Is this setup being ghosted elsewhere on my system?
