HomeAssistant + MQTT + MySensors Gateway & Node - almost there I think
I have been running OpenHab, Mosquitto (MQTT broker) and some home brew gateways and RF nodes. I have seen the light and clearly the MySensors platform and Home Assistant as my controller are the way to go. I’ve had a good go at getting it to work and I feel I’m close, but now I need some help.
For my test node I have a Moteino with RFM69W configured based on the MySensors sample code here https://home-assistant.io/components/mysensors/ and have put a switch (fixed not momentary type) on pin 8.
For my gateway between RF and Eth/MQTT I bought a MySensors SenseBender GW board (Arduino Zero variant) and soldered on an RFM69 and plugged in a W5100 Eth module. For the software I used a combination of the Examples > MySensors > SensebenderGatewaySerial example and the Examples > MySensors > GatewayW5100 example to create my MySensors MQTT GW code.
I used the sample Home Assistant configuration.yaml code from here https://home-assistant.io/components/mysensors/ but customised to just use the “- device: mqtt” section.
I also added an mqtt broker section to my configuration.yaml
My Home Assistant (v0.47.0) is running on an RPi3.
So whats the problem?
Well, when I press the button on the end node, it successfully transmits what looks like the right info to the gateway and the gateway in turn shoots the right MQTT packet over to the MQTT Broker (mosquitto) and then Home Assistant seems to receive it.
BUT unfortunately Home Assistant then instantly generates an error
2017-06-29 18:06:56 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on GWPUB/55/11/1/0/2: 0
2017-06-29 18:06:56 DEBUG (Thread-13) [homeassistant.components.mysensors] Update: node 55, child 11 sub_type 2
2017-06-29 18:06:56 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
    result = next(coro)
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
    "No entity id specified for entity {}".format(self.name))
homeassistant.exceptions.NoEntitySpecifiedError: No entity id specified for entity Switch Sensor 55 11
I have put a similar post in the MySensors forum in case the issue is with that side of things. But I would like to know if anyone can assist here with checking the Home Assistant side, or provide some examples of known working configs?
Thanks,
Paul
Here is my Node code
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
//#define MY_RADIO_NRF24
#define MY_RADIO_RFM69
#define MY_RFM69HW false
#define MY_RFM69_NETWORKID 101
#define MY_NODE_ID 55
#include <MySensors.h>
#include <Bounce2.h>
#define CHILD_ID_SW 11
#define CHILD_ID_REL 22
#define SW_PIN 8
#define REL_PIN 7
#define SW_ON 1
#define SW_OFF 0
MyMessage msgSW(CHILD_ID_SW, V_STATUS); // 16
//MyMessage msgREL(CHILD_ID_REL, V_LIGHT); //2
byte StateREL=0;
Bounce debouncer = Bounce();
int oldValueSW=-1;
int valueSW=0;
const unsigned long tUpdate=60000; //update interval if input do not change
unsigned long t0;
bool state = false;
bool initialValueSent = false;
void presentation() {
  sendSketchInfo("Node_Test", "0.1");
  present(CHILD_ID_SW, S_BINARY);
  //present(CHILD_ID_REL, S_LIGHT);
void setup() {
  pinMode(SW_PIN,INPUT);
  digitalWrite(SW_PIN,HIGH);
  debouncer.attach(SW_PIN);
  debouncer.interval(5);
  pinMode(REL_PIN, OUTPUT);
  digitalWrite(REL_PIN, StateREL);
  // get state of SW at powerup.
  debouncer.update();
  state = debouncer.read();
void loop()
  // If this is the first time loop has run, send initial value to Home Assistant.
  if (initialValueSent == false)
    Serial.println("Sending initial value");
    send(msgSW.set(state?SW_ON:SW_OFF), true); //and asking for an ACK
    initialValueSent = true;
    t0=millis();  // reset the interval timer so we don't send update until period expires.
  if (debouncer.update())
    if (debouncer.read()!= state)
      state = !state;
      // Send new state and request ack back
  if ((millis()-t0) > tUpdate)
void receive(const MyMessage &message) {
  if (message.isAck()) {
     Serial.println("Received an ack from gateway");
  else  {
     Serial.println("Received something but not an ack, from gateway");
Here is what it’s serial monitor looks like
0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
3 TSM:INIT
4 TSF:WUR:MS=0
6 TSM:INIT:TSP OK
8 TSM:INIT:STATID=55
10 TSF:SID:OK,ID=55
11 TSM:FPAR
142 TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
621 TSF:MSG:READ,0-0-55,s=255,c=3,t=8,pt=1,l=1,sg=0:0
626 TSF:MSG:FPAR OK,ID=0,D=1
2149 TSM:FPAR:OK
2150 TSM:ID
2151 TSM:ID:OK
2153 TSM:UPL
2160 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
2190 TSF:MSG:READ,0-0-55,s=255,c=3,t=25,pt=1,l=1,sg=0:1
2195 TSF:MSG:PONG RECV,HP=1
2198 TSM:UPL:OK
2199 TSM:READY:ID=55,PAR=0,DIS=1
2208 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
2225 TSF:MSG:READ,0-0-55,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
2280 TSF:MSG:SEND,55-55-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
2336 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
2403 TSF:MSG:READ,0-0-55,s=255,c=3,t=6,pt=0,l=1,sg=0:M
2459 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Node_Test
2516 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
2572 TSF:MSG:SEND,55-55-0-0,s=11,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
2578 MCO:REG:REQ
2630 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
2651 TSF:MSG:READ,0-0-55,s=255,c=3,t=27,pt=1,l=1,sg=0:1
2656 MCO:PIM:NODE REG=1
2658 MCO:BGN:STP
2660 MCO:BGN:INIT OK,TSP=1
2669 TSF:MSG:SEND,55-55-0-0,s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
2695 TSF:MSG:READ,0-0-55,s=11,c=1,t=2,pt=2,l=2,sg=0:0
2700 TSF:MSG:ACK
13868 TSF:MSG:SEND,55-55-0-0,s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
13892 TSF:MSG:READ,0-0-55,s=11,c=1,t=2,pt=2,l=2,sg=0:1
13897 TSF:MSG:ACK
18896 TSF:MSG:SEND,55-55-0-0,s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
18922 TSF:MSG:READ,0-0-55,s=11,c=1,t=2,pt=2,l=2,sg=0:0
18927 TSF:MSG:ACK
Here is my SenseBender MQTT Eth w5100 Gateway code
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <[email protected]>
* Copyright (C) 2013-2015 Sensnology AB
* Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* DESCRIPTION
* The ArduinoGateway prints data received from sensors on the serial link.
* The gateway accepts input on seral which will be sent out on radio network.
* This GW code is designed for Sensebender GateWay / (Arduino Zero variant)
* Wire connections (OPTIONAL):
* - Inclusion button should be connected to SW2
* LEDs on board (default assignments):
* - Orange: USB RX/TX - Blink when receiving / transmitting on USB CDC device
* - Yellow: RX  - Blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
* - Green : TX  - Blink fast on radio message transmitted. In inclusion mode will blink slowly
* - Red   : ERR - Fast blink on error during transmission error or recieve crc error
* - Blue  : free - (use with LED_BLUE macro)
#define SKETCH_VERSION "0.2"
#define MY_DEBUG
#define MY_DEBUG_VERBOSE
// Set LOW transmit power level as default, if you have an amplified NRF-module and
// power your radio separately with a good regulator you can turn up PA level.
//#define MY_RF24_PA_LEVEL RF24_PA_HIGH
// Enable serial gateway
//#define MY_GATEWAY_SERIAL
// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
#if F_CPU == 8000000L
#define MY_BAUD_RATE 38400
#endif
// Enable gateway ethernet module type
//#define MY_GATEWAY_W5100
// Enable gateway ethernet module type with MQTT
#define MY_GATEWAY_MQTT_CLIENT
// Set this node's subscribe and publish topic prefix
#define MY_MQTT_PUBLISH_TOPIC_PREFIX "GWPUB"
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "GWSUB"
// Set MQTT client id
#define MY_MQTT_CLIENT_ID "mysensors-gw"    // this is used when this gw connects to the MQTT Broker.
// MQTT broker ip address or url. Define one or the other.
//#define MY_CONTROLLER_URL_ADDRESS "m20.cloudmqtt.com"
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 200, 251   // HOMER my Raspi running Home Assistant and Mosquitto
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 200, 241   // HABPI my Raspi running OpenHAB and Mosquitto
// The MQTT broker port to to open
#define MY_PORT 1883
// Enable these if your MQTT broker requires usenrame/password
//#define MY_MQTT_USER "pimqtt"           // as generated when I installed Mosquitto on my Home Assistant RasPi.
//#define MY_MQTT_PASSWORD "lowsecpass"   // as generated when I installed Mosquitto on my Home Assistant RasPi.
// W5100 Ethernet module SPI enable (optional if using a shield/module that manages SPI_EN signal)
//#define MY_W5100_SPI_EN 4
// Enable Soft SPI for NRF radio (note different radio wiring is required)
// The W5100 ethernet module seems to have a hard time co-operate with
// radio on the same spi bus.
#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
#define MY_SOFTSPI
#define MY_SOFT_SPI_SCK_PIN 14
#define MY_SOFT_SPI_MISO_PIN 16
#define MY_SOFT_SPI_MOSI_PIN 15
#endif
// When W5100 is connected we have to move CE/CSN pins for NRF radio
#ifndef MY_RF24_CE_PIN
#define MY_RF24_CE_PIN 5
#endif
#ifndef MY_RF24_CS_PIN
#define MY_RF24_CS_PIN 6
#endif
// Enable to UDP
//#define MY_USE_UDP
// Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
#define MY_IP_ADDRESS 192,168,200,230
// Renewal period if using DHCP
//#define MY_IP_RENEWAL_INTERVAL 60000
// The port to keep open on node server mode / or port to contact in client mode
//#define MY_PORT 5003    // ONLY for MY_GATEWAY_W5100 mode.
// If using static ip you need to define Gateway and Subnet address as well
#define MY_IP_GATEWAY_ADDRESS 192,168,200,254
#define MY_IP_SUBNET_ADDRESS 255,255,255,0
// Controller ip address. Enables client mode (default is "server" mode). // ONLY for MY_GATEWAY_W5100 mode.
// Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere.
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
// The MAC address can be anything you want but should be unique on your network.
// Newer boards have a MAC address printed on the underside of the PCB, which you can (optionally) use.
// Note that most of the Ardunio examples use  "DEAD BEEF FEED" for the MAC address.
#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0x01, 0x01
// Enable inclusion mode
#define MY_INCLUSION_MODE_FEATURE
// Enable Inclusion mode button on gateway
#define MY_INCLUSION_BUTTON_FEATURE
// Inverses behavior of inclusion button (if using external pullup)
//#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
// Set inclusion mode duration (in seconds)
#define MY_INCLUSION_MODE_DURATION 60
// Digital pin used for inclusion mode button
//#define MY_INCLUSION_MODE_BUTTON_PIN  3
// Set blinking period
#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Inverses the behavior of leds on the Gateway
#define MY_WITH_LEDS_BLINKING_INVERSE
// Flash leds on rx/tx/err
// Uncomment to override default HW configurations
//#define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
//#define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
//#define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
#if defined(MY_USE_UDP)
#include <EthernetUdp.h>
#endif
#include <Ethernet.h>
#include <SD.h>
#include <drivers/ATSHA204/ATSHA204.cpp>
Sd2Card card;
#define EEPROM_VERIFICATION_ADDRESS 0x01
static uint8_t num_of_leds = 5;
static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
void setup()
	// Setup locally attached sensors
void presentation()
	// Present locally attached sensors
void loop()
	// Send locally attached sensor data here
 //if (Serial) {
 //      Serial.println(F("In Loop() "));
void preHwInit()
	pinMode(MY_SWC1, INPUT_PULLUP);
	pinMode(MY_SWC2, INPUT_PULLUP);
	if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
		return;
	uint8_t tests = 0;
	for (int i=0; i< num_of_leds; i++) {
		pinMode(leds[i], OUTPUT);
	uint8_t led_state = 0;
	if (digitalRead(MY_SWC1)) {
		while (!Serial) {
			digitalWrite(LED_BLUE, led_state);
			led_state ^= 0x01;
			delay(500);
		} // Wait for USB to be connected, before spewing out data.
	digitalWrite(LED_BLUE, LOW);
	if (Serial) {
		Serial.println("Sensebender GateWay test routine");
		Serial.print("Mysensors core version : ");
		Serial.println(MYSENSORS_LIBRARY_VERSION);
		Serial.print("GateWay sketch version : ");
		Serial.println(SKETCH_VERSION);
		Serial.println("----------------------------------");
		Serial.println();
	if (testSha204()) {
		digitalWrite(LED_GREEN, HIGH);
		tests++;
	if (testSDCard()) {
		digitalWrite(LED_YELLOW, HIGH);
		tests++;
	if (testEEProm()) {
		digitalWrite(LED_ORANGE, HIGH);
		tests++;
	if (testAnalog()) {
		digitalWrite(LED_BLUE, HIGH);
		tests++;
	if (tests == 4) {
		while(1) {
			for (int i=0; i<num_of_leds; i++) {
				digitalWrite(leds[i], HIGH);
				delay(200);
				digitalWrite(leds[i], LOW);
	} else {
		while (1) {
			digitalWrite(LED_RED, HIGH);
			delay(200);
			digitalWrite(LED_RED, LOW);
			delay(200);
bool testSha204()
	uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
	uint8_t ret_code;
	if (Serial) {
		Serial.print("- > SHA204 ");
	atsha204_init(MY_SIGNING_ATSHA204_PIN);
	ret_code = atsha204_wakeup(rx_buffer);
	if (ret_code == SHA204_SUCCESS) {
		ret_code = atsha204_getSerialNumber(rx_buffer);
		if (ret_code != SHA204_SUCCESS) {
			if (Serial) {
				Serial.println(F("Failed to obtain device serial number. Response: "));
			Serial.println(ret_code, HEX);
		} else {
			if (Serial) {
				Serial.print(F("Ok (serial : "));
				for (int i=0; i<9; i++) {
					if (rx_buffer[i] < 0x10) {
						Serial.print('0'); // Because Serial.print does not 0-pad HEX
					Serial.print(rx_buffer[i], HEX);
				Serial.println(")");
			return true;
	} else {
		if (Serial) {
			Serial.println(F("Failed to wakeup SHA204"));
	return false;
bool testSDCard()
	if (Serial) {
		Serial.print("- > SD CARD ");
	if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
		if (Serial) {
			Serial.println("SD CARD did not initialize!");
	} else {
		if (Serial) {
			Serial.print("SD Card initialized correct! - ");
			Serial.print("type detected : ");
			switch(card.type()) {
			case SD_CARD_TYPE_SD1:
				Serial.println("SD1");
				break;
			case SD_CARD_TYPE_SD2:
				Serial.println("SD2");
				break;
			case SD_CARD_TYPE_SDHC:
				Serial.println("SDHC");
				break;
			default:
				Serial.println("Unknown");
		return true;
	return false;
bool testEEProm()
	uint8_t eeprom_d1, eeprom_d2;
	SerialUSB.print(" -> EEPROM ");
	Wire.begin();
	eeprom_d1 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
	delay(500);
	eeprom_d1 = ~eeprom_d1; // invert the bits
	i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
	delay(500);
	eeprom_d2 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
	if (eeprom_d1 == eeprom_d2) {
		SerialUSB.println("PASSED");
		i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
		return true;
	SerialUSB.println("FAILED!");
	return false;
bool testAnalog()
	int bat_detect = analogRead(MY_BAT_DETECT);
	Serial.print("-> analog : ");
	Serial.print(bat_detect);
	if (bat_detect < 400 || bat_detect > 650) {
		Serial.println(" Failed");
		return false;
	Serial.println(" Passed");
	return true;
And here are what I think are the relevant sections of my Home Assistant configuration.yaml
logger:
  default: info   #ignore any messages below this level. PJ - I often use 'info' here.
  logs:
    homeassistant.components.mqtt: debug
    homeassistant.components.mysensors: debug
mqtt:
  broker: habpi     # my mosquitto based broker on my habpi box.
  port: 1883
  client_id: homer_home_assist
  keepalive: 60
  birth_message:                #this MQTT message gets sent every time Home Assistant starts up or is restarted.
    topic: 'home/hass/status'
    payload: 'online'
  will_message:
    payload: 'offline'
mysensors:
  gateways:
    - device: mqtt
      persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
      topic_in_prefix: 'GWPUB'
      topic_out_prefix: 'GWSUB'
  optimistic: false
  persistence: true
  retain: true
  version: 2.0
i love mysensors, but i never used mqtt.
i hope i get this right.
my way:
mysensors node => mysensors serial gateway => HA
mqtt way (as i see it)
mysensors node => mysensors mqtt gateway => mqtt broker => HA
or
mysensors node => mysensors mqtt gateway => HA (through mqtt protocol)
and as i see it you use both (so i think you should use mqtt broker or mysensors in the config)
if you dont use the mqtt for anything else then for HA i would reprogram your gateway to a normal ethernet gateway and connect HA to that.
but then again i could be completely wrong :wink:
when i see the error, i suspect that the node isnt presented to HA before the value update.
This issue is a consequence of the core change to async in home assistant. I want to fix it, but it’s not quite ready yet.
Issue also tracked here:
https://github.com/home-assistant/home-assistant/issues/8243
Ahh ok, thanks @martinhjelmare I appreciate the effort.
Thanks,
Paul
Hi guys, any news on this?
If you mean the error NoEntitySpecifiedError, I’m working on a refactor of mysensors component that will include a fix. I’m aiming for release in 0.51, ie +2 weeks.
The error should now be fixed in 0.52.
Thanks @martinhjelmare I’ll test it out when I get the chance to upgrade.
Thanks,
Paul
