My HA worked fine, but when i woke up this morning i saw my zigbee entities had disappeared. I figured a reboot would do the trick, but it didn’t. Lovelace is unavailable, terminal, samba and ssh are available. Observer is reachable via http.
Can anyone shed some light?
Hassio on a RPi4b
Log:
2023-10-28 10:33:54.430 ERROR (MainThread) [root] Uncaught exception
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 216, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 204, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 186, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 152, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 155, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 268, in async_from_config_dict
await hass.config_entries.async_initialize()
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1176, in async_initialize
for entry in config["entries"]:
KeyError: 'entries'
