Continuing the discussion from ESPHome - Change IP address OTA:
I have successfully changed the IP address, but HA is still looking for it on the old IP and the Device/Entity shows up as unavailable. I cannot even delete the device.
Any suggestions?
A second identical unit works fine (when the Ip was changed). New IP is 192.168.2.66
2022-03-23 12:17:07 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for garage1 @ 192.168.7.66: Error connecting to ('192.168.7.66', 6053): [Errno 113] Connect call failed ('192.168.7.66', 6053)
I am not sure if this is an ESPHome bug, an ESPHome Integration bug or an HA bug!
INFO Reading configuration /config/esphome/garage1.yaml...
INFO Starting log output from 192.168.2.66 using esphome API
INFO Successfully connected to 192.168.2.66
[12:20:45][I][app:102]: ESPHome version 2022.2.4 compiled on Mar 23 2022, 12:11:17
[12:20:45][C][wifi:491]: WiFi:
[12:20:45][C][wifi:353]: Local MAC: 48:3F:DA:8D:A3:42
[12:20:45][C][wifi:354]: SSID: [redacted]
[12:20:45][C][wifi:355]: IP Address: 192.168.2.66
[12:20:45][C][wifi:356]: BSSID: [redacted]
[12:20:45][C][wifi:358]: Hostname: 'garage1'
[12:20:45][C][wifi:360]: Signal strength: -77 dB ▂▄▆█
[12:20:45][C][wifi:364]: Channel: 7
[12:20:45][C][wifi:365]: Subnet: 255.255.255.0
[12:20:45][C][wifi:366]: Gateway: 192.168.2.1
[12:20:45][C][wifi:367]: DNS1: 192.168.7.29
[12:20:45][C][wifi:368]: DNS2: 0.0.0.0
[12:20:45][C][logger:233]: Logger:
[12:20:45][C][logger:234]: Level: DEBUG
[12:20:45][C][logger:235]: Log Baud Rate: 115200
[12:20:45][C][logger:236]: Hardware UART: UART0
[12:20:45][C][switch.gpio:050]: GPIO Switch 'Garage Door 1 Relay'
[12:20:45][C][switch.gpio:051]: Pin: GPIO4
[12:20:45][C][switch.gpio:073]: Restore Mode: Always OFF
[12:20:45][C][template.switch:058]: Template Switch 'Garage Door 1'
[12:20:45][C][template.switch:058]: Icon: 'mdi:gate'
[12:20:45][C][template.switch:059]: Restore State: NO
[12:20:45][C][template.switch:060]: Optimistic: NO
[12:20:45][C][captive_portal:144]: Captive Portal:
[12:20:45][C][mdns:084]: mDNS:
[12:20:45][C][mdns:085]: Hostname: garage1
[12:20:45][C][ota:085]: Over-The-Air Updates:
[12:20:45][C][ota:086]: Address: 192.168.2.66:8266
[12:20:45][C][api:138]: API Server:
[12:20:45][C][api:139]: Address: 192.168.2.66:6053
[12:20:45][C][api:143]: Using noise encryption: NO
