Homeassistant on PC is different from one for the raspberry pi
I am running hass on raspberry pi 3 and it seems that the board is struggling when multiple plugins are up and running, so I decided to use my old pc instead (old mac mini from 2012 with Ubuntu installed). I installed docker and run hass in docker and everything works fine.
But there is a problem with the version that I run on a pc, it is missing addons, backups so I cannot install anything (node red, zigbee2mqtt, mosquito).
Also, I find a bit confusing the documetation and cannot figure out why am I missing this section.
Can you please help me to solve this problem, is hat am I missing here?
Thanks :blush:
I think you better start by details which of the installation methods you used.
Did you install a Generic x86-64 HA OS install (the best way to run on PC hardware, I have run this on a NUC and it was great) or did you run under Docker or as a VM?
Once that is known then better experts than me can tell you the difference between each install method and what is available under each.
You installed OS on your pi and container on your PC, see this table of supported features depending on install method:
https://www.home-assistant.io/installation/#compare-installation-methods
