I have win10 and installed Hyper-V. I can run hassio without any problem, but I can’t setup share use devices like stick CC2531 or deconz. Did someone know how to setup it?
I saw some solutions like share with “enchanted session” and some tools which share USB devices by the network but all of them don’t work with hassio.
as said, the only way is to use SW like usb redirector, but needs install on both host and guest.
Since hassOS is so strict as OS i don’t think it’s possible to use them.
You can do it if you use your own linux os ( ubuntu, debian, centos ) and then install HA core or supervised on linux.
I did a test with bluetooth from host hyper-v to ubuntu guest and it was working fine.
