I am currently running HA OS on unraid and have 2x 15.6" touchscreens with RaspberryOS desktop used for displaying and control the entities.
I would like to install HA OS on one of the touchscreen Pis instead of unRAID so I can turn of the server and still have control of my home.
I know how to install HA OS on a Pi (had it running in the past).
I want one Pi to run HA OS and a web browser “vieweing” itself (127.0.0.1) and the other Pi will still run just a web browser with RaspberryOS desktop pointing to the 1st one.
My question is how can I install HA OS and a web browser on the same Pi to be used with the touchscreen?
Hassio is a name that was dropped in January 2020. That install method is as you said in the title, now called Home Assistant OS.
However, you can’t do what you want with that install method. You could do it with the Container install method, but IMO you’re better off with a second Pi - or to leave it on unRAID.
Just found it also but in the Debian 10 guide requirements it is stated that cannot run additional SW in parallel to HA OS supervised (I need some type of desktop and chromium).
Hi all, I have and old tablet x86 with touch screen that I would like to leverage with HA OS 2025.9.4. It would be good if I could run a basic web browser in the same tablet running HA OS. It will not be a problem with space or processor capabilites, but just wondering if there are some way to add a package to HA OS enabling a web browser than can be launch from the ha> command. I would like to avoid install linux + container as I will not use rest of the hosting OS capabilities (just the browser). thanks for the guidance.
