HomeAssistant + Pi Hole = Interface Web No Access
I cant access homeassistant web interface after install of the Pi hole.
Situation
Pi hole: 100% working
Home assistant Interface web (internet): no working
Home assistant Intranet: 100% working
My configuration:
Raspbian Stretch + Pi 3 + Homeassistant + Pi Hole
IP
Pi Hole 192.168.0.107
Homeassistant: 192.168.0.107:8123
Domain Duckdns + Letsencrypt: mydomain.duckdns.org
Configuration.yaml
Texto pré-formatadohttp:
api_password: !secret api_password
ssl_certificate: /etc/letsencrypt/live/mydomain.duckdns.org/fullchain.pem
ssl_key: /etc/letsencrypt/live/mydomain.duckdns.org/privkey.pem
base_url: mydomain.duckdns.org:8123Texto pré-formatado
Router PortForwarding
External Internal
1883 TCP e UDP 1883 192.168.0.107 1883
8123 TCP e UDP 8123 192.168.0.107 8123
PiHole shouldn’t affect things coming from the outside in but instead from the inside out. Have you tried, externally, to make sure your address is current and up to date? A simple ping from outside your network should let you know.
Returned on working.
But i didnt do nothing.
You should assign external port 443 if you are using ssl , and change the base_url to mydomain.duckdns.org:443
I don’t think that Pihole has anything to do with it, as it is running on port 80 (http) only. (unless you have setup ssl for pihole of course)
Thanks, my friend.
