switch in the configuration.yaml -
switch:
- platform: rpi_gpio
ports:
22: TestLED1
12: TestLED2
- platform: command_line
switches:
medium:
command_on: 'python3 /home/pi/pwm-led-medium.py'
command_off: 'python3 /home/pi/pwm-led-mediumoff.py'
switches:
high:
command_on: 'python3 /home/pi/pwm-led-high.py'
python code medium.py -
#!/usr/bin/python3
import RPi.GPIO as GPIO # Remember to run as superuser (sudo)
import time
print("LED DIMMER USING PULSE WIDTH MODULATION")
GPIO.cleanup()
GPIO.setmode(GPIO.BCM) # This example uses the BCM pin numbering
GPIO.setup(12, GPIO.OUT) # GPIO 25 is set to be an output.
pwm = GPIO.PWM(12, 144) # pwm is an object. This gives a neat way to control the pin.
pwm.stop()
# 25 is the BCM pin number.
# 10 is the frequency in Hz.
print("25%") # Display 50 on the screen
pwm.start(0)
pwm.ChangeFrequency(255) # This 50 is the mark/space ratio or duty cycle of 50%
pwm.ChangeDutyCycle(75) # Values from 0 to 100 are allowed including numbers like 33.33
while True:
time.sleep(.01) # Infinite loop
pwm.stop() # Turn PWM off
GPIO.cleanup() # Always clean up at the end of programs.
python code high.py -
#!/usr/bin/python3
import time
GPIO.cleanup()
pwm.stop()
pwm.start(0)
pwm.ChangeDutyCycle(100) # Values from 0 to 100 are allowed including numbers like 33.33
while True:
When I switch between the two in home assistant, they constantly blink and go back and forth. I’m not sure what I’m doing wrong and am completely stuck. Please help!
