Homeassistant/restart broken using 29.1
Hello, another fantastic update from hass, so huge thanks for this!
just updated to 29.1 and noticed that homeassistant/restart does not work now from the gui
i get the little notification to say it has been called but hass is definitely not restarting
also nothing in the logs that seems in any way related
i noticed this as well in an earlier release already i have made an issue for it a few days ago
Until it is fixed, here is how to do a restart from the command line:
sudo systemctl restart home-assistant
yeah, thanks - although i actually use a synology docker container so i restart the container from the command line (but usually i have the synology GUI open so can just restart hass from there instead)
ah thanks - i always forget to look at the github pages!
I can’t even restart using the command…ugh.
I just tested trying a restart form the GUI and can confirm @jimbob1001’s findings.
I’ll note it on @joyrider3774’s issue; other should too.
