Just noticed that my Homeassistant (ha core) running on an RPi5, broadcasts to port 5353 more than 100 times/minute.
I assume this is part of Bonjour/Avahi network discover but this shouldn’t be happening at such high frequency. Also, this behavior seems to only have started recently (but I can’t say for sure)
The syslog on one of my Linux machines shows multiple repeated entries of the following form generated by iptables:
I have dozens of Linux, Windows, iPhone, Android and RPi devices on my network and none of them broadcast on 5353 anywhere near 100 times a minute. More like a couple of times an hour.
There appears to be something different/wrong with Home Assistant that makes it attempt Network discovery so frequently. After all, does one expect the network config to change multiple times a second???
Iptables IS CONFIGURED PROPERLY AND INTENTIONALLY SO – it is set up to block exploits that try to flood 5353 multicasts Sending out 5353 multicasts more than 100 times a minute fits that definition.
Mentioning hardware and OSes makes no sense here.
MDNS is a service, so what are you running on that list that makes use of mDNS?
Your IPTables rules might make sense for a basic simple consumer network, but it does not take into account an IoT network, which device countwise more looks like an enterprise network.
You need to understand the services and protocols in your network and how they are used to set up restriktive rules for them!
You can of course decide to run HA supervised and then limit the mDNS packets there, but when a sensor miss a discovery request, then it will be unavailable in HA until the sensor itself sends a announcement broadcast.
As you can see on your other devices this might mean several hours without updates.
Yes but sending out requests ~200 times a minute seems excessive.
Note that per the RFC 6762 for mDNS, it should never multicast its own identity more than once per second. So, HA seems to be violating the mDNS RFC
And if it’s querying for other devices, I only have a couple of IoT devices on my network and it should at least be caching their IP addresses rather than requerying every second. If I had hundreds of IoT devices this would be killing my WiFi network with thousands of useless mDNS packets a second (this is a real problem on large public WiFi networks where even mDNS packets a couple times a minute can cause problems)
Also, it only seems to have started doing this in the last few days and not sure what changed to cause the issue as I don’t think I did anything to HA recently.
I also have Google Home and Alexa on my network that are attached to the very same IoT devices (actually more) and they multicast 5353 only a few times an hours.
So something seems broken or at least changed.
Also, my iptables is not on the HomeAssistant device but on my home server. It is getting flooded by mDNS from the RPi5 running Home Assistant. Note that a regular RPi running Raspbian only sends out a handful of mDNS requests per minute vs. ~200 for HomeAssistant.
mDNS can flood large corporation network with many thousand of devices, so you normally segment the networks then.
We have around 5000-6000 devices per segment at my work at in handle it fine.
Your network gear should do fine too or it will be crap.
A mDNS packet is based on UDP and most packets that come from HA are service discoveries, which is pretty close to the minimum UDP packet size of around 60 bytes. A common packet size when you stream a movie will be 1500 bytes and the packet counts per minute of those will be higher than any mDNS count you can experience on a home network.
You should put a packet grabber, like wireshark, on your network and see what the traffic actually is.
mDNS is not just a decentralized name lookup service, nor is DNS inside LANs anymore.
The mdns packets all include _airplay._tcp.local
I wonder whether HA is detecting the mythtv instances as an airplay device and is interacting with it that way.
Is airplay part of HA? Is it possible to turn it off?
HA most likely support the airplay protocol also, but airplay can also just be a standard service thing in mDNS also.
mDNS is an apple thing turned general.
