hi all,
I am trying to get a basic button to work to turn on /off a light in my home. I have the following config:
# Basic device configuration
esphome:
platform: ESP32
board: esp32dev
# WiFi configuration
wifi:
networks:
- ssid: 'C1'
password: 'REDACTED'
manual_ip:
static_ip: 192.168.99.141
gateway: 192.168.99.254
subnet: 255.255.255.0
dns1: 192.168.99.254
# Enable logging
logger:
level: VERBOSE # Increase logging level
# Enable Home Assistant API
api:
encryption:
key: "REDACTED"
ota:
platform: esphome
# Button configuration
binary_sensor:
- platform: gpio
pin:
number: GPIO4 # Change this to your button's GPIO pin
mode: INPUT_PULLUP # Enable internal pull-up resistor
inverted: true # Invert the input (button connects to GND)
on_click:
then:
- homeassistant.event:
event: esphome.button_pressed
message: "Button1 singel"
- logger.log: "Button pressed!"
- homeassistant.service:
service: light.turn_on
entity_id: light.lamp_achter_tv_socket_1
I am trying to debug where it is going wrong. It seems the homeassistant.service and homeassistant.events don’t work. I don´t see any events when i listen on the event and the service is also not working. How can i debug this more? I see the message “Button pressed” from the logger in the console but i can’t seem to debug the api calls to homeassistant.
