I just moved all my Tasmota sockets to ESPHome and just flashed my sonoff wall switch (touch 3 gang) on ESPHome too.
On Tasmota, I used MQTT to be able to switch another device via multi-click.
I understand esp node to node control is still a feature request.
I tried the native api request via http with failure. I resorted to call home assistant to do the changes in the automation but failed equally.
Can someone point me to the right direction. This is my esphome code:
# Device Specific Config for sonoff-t1-3ch
#button3 turns on relay3 for the light
#button2 to turn a fog light via Home Assistant.
binary_sensor:
- platform: gpio
pin:
number: GPIO10
mode: INPUT_PULLUP
inverted: True
on_press:
if:
condition:
- switch.is_off: relay3
then:
- switch.turn_on: relay3
else:
- switch.turn_off: relay3
- platform: gpio
pin:
number: GPIO9
mode: INPUT_PULLUP
inverted: True
on_press:
- homeassistant.service:
service: switch.toggle
entity_id: switch.rfr3_switch_front_fog
switch:
- platform: gpio
pin: GPIO4
