Hello, it seems that every time I try to start homeassistant, it comes with the following errors. Only about 1/3 of the time it works. I have everything finally set up the way I want it, but now I want to have it auto start when plugged in, but it only works about 1/3 of the time… Even the wake word agent fails half the time. Please check out the following code.
1st Try Failed:
pi@raspberrypi:~ $ ./start_alexa.sh
Starting sample app.
When finished
Press space to continue...
pi@raspberrypi:~ $ INFO:main: Starting Wake Word Agent
INFO:WakeWordAgent: State set to IDLE(2)
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
INFO:KittAiSnowboyWakeWordEngine: thread started
INFO:WakeWordIPCSocket::mainLoop thread started
INFO:WakeWordIPCSocket: init socket on port:5123
INFO:WakeWordAgent: thread started
INFO:Not connected! Make sure AVS client is running
> [email protected] start /home/pi/Desktop/alexa-avs-sample-app/samples/companionService
> node ./bin/www
This node service needs to be running to store token information memory and vend them for the AVS app.
Listening on port 3000
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building Alexa Voice Service Sample Java Client 20160207.4
[INFO]
[INFO] --- exec-maven-plugin:1.2.1:exec (default-cli) @ sample-java-client ---
INFO:===> Connected to AVS client <===
INFO:WakeWordAgent: IPC Command received:4
Successfully retrieved access token for session id: 5bc27769-a172-46f8-914a-6f6793ccaf9d
INFO:WakeWordAgent: IPC Command received:3
INFO:WakeWordAgent: State set to WAKE_WORD_PAUSE_REQUESTED(5)
INFO:KittAiSnowboyWakeWordEngine: handling pause
INFO:KittAiSnowboyWakeWordEngine: releasing portAudio
INFO:WakeWordAgent: State set to WAKE_WORD_PAUSED(6)
22:10:51.663 [AWT-EventQueue-0] ERROR com.amazon.alexa.avs.ui.ListenView - An error occured creating speech request
java.lang.NullPointerException
at com.amazon.alexa.avs.AVSController.getMicrophoneInputStream(AVSController.java:338) ~[classes/:?]
at com.amazon.alexa.avs.AVSController.startRecording(AVSController.java:315) ~[classes/:?]
at com.amazon.alexa.avs.ui.ListenView.listenButtonPressed(ListenView.java:81) ~[classes/:?]
at com.amazon.alexa.avs.ui.ListenView.lambda$new$0(ListenView.java:71) ~[classes/:?]
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) [?:1.8.0_131]
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) [?:1.8.0_131]
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) [?:1.8.0_131]
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) [?:1.8.0_131]
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) [?:1.8.0_131]
at java.awt.Component.processMouseEvent(Component.java:6533) [?:1.8.0_131]
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) [?:1.8.0_131]
at java.awt.Component.processEvent(Component.java:6298) [?:1.8.0_131]
at java.awt.Container.processEvent(Container.java:2236) [?:1.8.0_131]
at java.awt.Component.dispatchEventImpl(Component.java:4889) [?:1.8.0_131]
at java.awt.Container.dispatchEventImpl(Container.java:2294) [?:1.8.0_131]
at java.awt.Component.dispatchEvent(Component.java:4711) [?:1.8.0_131]
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) [?:1.8.0_131]
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525) [?:1.8.0_131]
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) [?:1.8.0_131]
at java.awt.Container.dispatchEventImpl(Container.java:2280) [?:1.8.0_131]
at java.awt.Window.dispatchEventImpl(Window.java:2746) [?:1.8.0_131]
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) [?:1.8.0_131]
at java.awt.EventQueue.access$500(EventQueue.java:97) [?:1.8.0_131]
at java.awt.EventQueue$3.run(EventQueue.java:709) [?:1.8.0_131]
at java.awt.EventQueue$3.run(EventQueue.java:703) [?:1.8.0_131]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_131]
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80) [?:1.8.0_131]
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90) [?:1.8.0_131]
at java.awt.EventQueue$4.run(EventQueue.java:731) [?:1.8.0_131]
at java.awt.EventQueue$4.run(EventQueue.java:729) [?:1.8.0_131]
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) [?:1.8.0_131]
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) [?:1.8.0_131]
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) [?:1.8.0_131]
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) [?:1.8.0_131]
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) [?:1.8.0_131]
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) [?:1.8.0_131]
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) [?:1.8.0_131]
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.amazon.alexa.avs.AVSController.stopRecording(AVSController.java:604)
at com.amazon.alexa.avs.ui.ListenView.listenButtonPressed(ListenView.java:86)
at com.amazon.alexa.avs.ui.ListenView.access$200(ListenView.java:34)
at com.amazon.alexa.avs.ui.ListenView$SpeechRequestListener.onRequestError(ListenView.java:108)
at com.amazon.alexa.avs.AVSController.startRecording(AVSController.java:323)
2nd Try Failed:
When finished
ERROR:Failed to open PortAudio stream.Device unavailable
ERROR:KittAiSnowboyWakeWordEngine: Initialization error:Failed to open PortAudio stream.
ERROR:WakeWordAgent: exception in constructor: Failed to open PortAudio stream.
ERROR:main: Exception happened: Failed to open PortAudio stream.
INFO:Shutting down Wake Word Agent
> node ./bin/www
Port 3000 is already in use
npm ERR! [email protected] start: `node ./bin/www`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is most likely a problem with the alexa-voice-service-sample-companion-service package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node ./bin/www
npm ERR! You can get their info via:
npm ERR! npm owner ls alexa-voice-service-sample-companion-service
npm ERR! There is likely additional logging output above.
npm ERR! System Linux 4.9.35-v7+
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "start"
npm ERR! cwd /home/pi/Desktop/alexa-avs-sample-app/samples/companionService
npm ERR! node -v v0.10.29
npm ERR! npm -v 1.4.21
npm ERR! code ELIFECYCLE
npm WARN This failure might be due to the use of legacy binary "node"
npm WARN For further explanations, please read
/usr/share/doc/nodejs/README.Debian
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /home/pi/Desktop/alexa-avs-sample-app/samples/companionService/npm-debug.log
npm ERR! not ok code 0
[INFO]
[INFO]
22:16:53.869 [AWT-EventQueue-0] ERROR com.amazon.alexa.avs.ui.ListenView - An error occured creating speech request
