Hi all,
I have installed Home Assistant on a Debian with Docker.
I would like to expose it externally as https ://www.mysite.org/ha
I already have other apps configured and working like https ://www.mysite.org/app1, https ://www.mysite.org/app2, etc. and www.mysite.org has the correct SSL certificate, which I would like to use with Home Assistant via Apache reverse proxy.
I read some articles about this, but I didn’t solve:
- https ://www.mysite.org/ha responds with a “400: Bad Request”
- I tried to change the external url to HA from the settings, but I get a “url is not allowed to have a path component for dictionary value @ data[‘external_url’]. Got https ://www.mysite.org/ha’”
- I read that it might be necessary to remove the base_url, but where can I find the configuration.yaml file?
This is my apache configuration (sorry if it’s not the best one :():
<VirtualHost *:80>
ServerAdmin [email protected]
DocumentRoot /var/www/html/
ServerName mysite.org
ServerAlias www.mysite.org
Permanent redirect / https://www.mysite.org/
</VirtualHost>
<VirtualHost *:443>
Alias /zm /usr/share/zoneminder/www
ScriptAlias /cgi-bin "/usr/lib/cgi-bin"
#CrowdSecurity
ProxyPass "/cs" "http://localhost:3000"
ProxyPassReverse "/cs" "http://localhost:3000"
# RSpamD
RewriteEngine on
ProxyPass "/rspamd" "http://localhost:11334"
ProxyPassReverse "/rspamd" "http://localhost:11334"
RewriteRule ^/rspamd$ /rspamd/ [R,L]
RewriteRule ^/rspamd/(.*) http://localhost:11334/$1 [P,L]
# HomeAssistant
RewriteEngine on
ProxyPass "/ha" "http://localhost:8123"
ProxyPassReverse "/ha" "http://localhost:8123"
ProxyPass "/ha/api/websocket" "ws://localhost:8123/api/websocket"
ProxyPassReverse "/ha/api/websocket" "ws://localhost:8123/api/websocket"
#RewriteRule ^/ha$ /ha/ [R,L]
#RewriteRule ^/ha/(.*) http://localhost:8123/$1 [P,L]
#RewriteCond %{HTTP:Upgrade} =websocket [NC]
#RewriteRule /ha/(.*) ws://localhost:8123/$1 [P,L]
#RewriteCond %{HTTP:Upgrade} !=websocket [NC]
#RewriteRule /ha/(.*) http://localhost:8123/$1 [P,L]
Aliases / /var/www/html/nextcloud/
<Directory /var/www/html/nextcloud/>
Any ideas?
Thank you,
Matteo
