Hi all,
I’m running Homeassistant on a Synology DS918+ on a VM.
I noticed the used storage keeps on increasing in Synology VMM.
It currently is at ~30GB.
Comparing this by df -h command I see a delta of ~10GB:
Any ideas why this is different?
I installed portainer to see if there are old images/containers which could be removed. This was not the case. I did had several homeassistant backups with a size of ~6.5GB. I removed them from the VM (via samba share addon). However, the size reported by the VMM of Synology still reports ~30GB.
Via df -h I do see that the storage has been reduced:
Any ideas why the reported size by Synology VMM differs so much and how to get it reduced? In an earlier homeassistant VM it ran out of space, blocking even startup of homeasstant. Needed to re-install homeassistant with a clean VM install…
Another thing I noticed:
When I create a backup, VS code is taking the biggest part (~500MB zipped, ~2.5GB unzipped). The extensions take the biggest part of the data (~2.2GB). Is this normal?
Thx for in advance for thinking along!
Regards, Ruud
