HomeAssistant VMBox issue
Dear all, its me again.
Trying to set up and run HA on Oracle VMBox.
after following all steps from Windows - Home Assistant
I got stuck here, and there is no indications of what to do…
what is the next step, i cant go anywhere from here…
PS - unique diference is that im using 4cpu, and not 2.
Thank you <3
Open a browser and navigate to either 192.168.31.127:8123 or http://homeassistant.local:8123
The reported IP address is 192.168.31.127/24. It’s possible this is a private network internal to VirtualBox and not exposed to the local network. If you are able to, trying logging in to your router to see if HA is being given a DHCP lease. Or you can check your local network settings to see if your netmask allows access to this subnet. If you are on e.g. 192.168.1.x/24 then you may not be able to access the network and may need to reconfigure your netmask.
